Ascensi
Ascensi
Visits: 1.9K
Kevin.S
Kevin.S
Posts: 1.2K,
Visits: 71.8K
Some free advice ;)Before you charge people $10.00 for this you may want to explain more about it how it works etc Maybe show a demo video of it being used in iclone the set up etc. :D
Does it work with the current water system? Can you adjust the water like the current system? Can you change the water direction size height It says you can use it in CC how ? etc etc etc...
You state in your own txt on the store I haven't tried using the iClone water textures, maybe they are better? Tip Selling something you haven't even tried your self is just not a wise thing :D
Also this is the showcase artwork section of the forum not products :D
Freelance Artist Kevin.S
Email: animatemyart@gmail.com - Web Site: www.animatemyart.com
Ascensi
Ascensi
Visits: 1.9K
Kevin.S (10/9/2019)
Hi thanks! yes I realize the info needs to be refined.. a lot of what you were inquiring about is actually listed in the txt file and in the description. The description area had limited what i wanted to post. To answer your questions is yes you can alter the speed, wave height.. I haven't used Reallusions water textures because I was making something for IRAY to begin with and I'm not including their water textures. I've used the iClone water but wasn't compatible with IRAY so I made something that does work. The wave system also works with iClone. About show casing portfolio, yes I found the right thread after this post. This "system" is a plane with UV animation but many other settings and physics setup, it's just a practical way to make things work. When someone loads the project and presses play they will immediately see it work. Unfortunately for me if I created a demo of using it in iClone it would expose many settings that would allow another to reproduce.. so instead I do provide the settings such as specific material channel,physics and tools/models that can be changed for different scenarios and what must not be changed. I could make a private video tutorial that becomes available after purchase and will probably look into that soon. Thanks for the heads up :)
Store Page Link
       AMD 4.5 GHz 16 Cores | 128 GB | RTX 4090 | Window11 | Houdini FX 18.5 | Zbrush 2023 | Maya 2014 | Adobe CS6 | Sonar Producer X3 | iC8, CC4 | DTS Master Audio Suite | Perception Neuron 32 Alum Edition | Akeytsu
charly Rama
charly Rama
Posts: 1.9K,
Visits: 17.3K
It looks very promising, like Kevin, I'm waiting for more convincing videos before buying this, I think there are lot of improvements you can do for this , very interesting anycase
Ascensi
Ascensi
Visits: 1.9K
toystorylab
toystorylab
Last Active: 8 hours ago
Posts: 4.6K,
Visits: 29.9K
Thanx for the brilliant idea... I took the plunge, bought it and gave it a try. Here is my first result: That's good enough for me to get some ocean in my movies... Thanx ;)
Ascensi
Ascensi
Visits: 1.9K
charly Rama
charly Rama
Posts: 1.9K,
Visits: 17.3K
Thank you guys, this is my next acquisition. Very big potential
toystorylab
toystorylab
Posts: 4.6K,
Visits: 29.9K
Ascensi (10/10/2019) I'm working on boat physics update so basically the waves will influence the boat, or maybe dead bodies floating in your case ;) and I think just simply having a path for the boats to follow will allow freedom for boat physics!That would be very cool, as it is very tedious and tricky to fake that cause you can't see the waves as you scrub the timeline...
