LOD Export not Working in Unity
Posted By abranchfie 6 Years Ago
abranchfie
abranchfie
Veteran Member (505 reputation)Veteran Member (505 reputation)Veteran Member (505 reputation)Veteran Member (505 reputation)Veteran Member (505 reputation)Veteran Member (505 reputation)Veteran Member (505 reputation)Veteran Member (505 reputation)Veteran Member (505 reputation)
Posts: 12, Visits: 156
I'm having a problem exporting an LOD model into Unity.  When I export the model with the LOD settings the separate LOD files and texture folders are not being generated.  I'm using the exact steps that are shown in the Realusion video about Setting up LOD for CC3 character in Unity3d.  At 11:07 in the tutorial it shows a folder after export containing all of the LOD fbx files and their respective texture folders.  Prior to CC 3.11 when I did this all of these file were in the folder.  Now the file structure created lacks all of these files.  When I import into Unit 2019.2 I get the warning "Inconsistent LOD naming (_LOD1 found but no _LOD0)" which isn't surprising since it's not in the folder that I import.  Has something change in CC3.11 because the video above worked before?  I've created many LODs before 3.11 without ever having a problem.  These are the files created now:
https://forum.reallusion.com/uploads/images/71d3cc9b-3d8c-4e05-94c9-2b0c.jpg
deidrereaystudios
deidrereaystudios
Veteran Member (747 reputation)Veteran Member (747 reputation)Veteran Member (747 reputation)Veteran Member (747 reputation)Veteran Member (747 reputation)Veteran Member (747 reputation)Veteran Member (747 reputation)Veteran Member (747 reputation)Veteran Member (747 reputation)
Posts: 43, Visits: 346
Is anyone going to address this issue. We are having the same thing.
Basically once in unity the final lod (culling) is and will not happen.
Can someone please help on this issue.
Thanks in advance
deidrereaystudios
deidrereaystudios
This is soft error inside untiy when lod loaded character is imported.
Inconsistent LOD naming (_LOD1 found but no _LOD0).
UnityEditorInternal.InternalEditorUtility:ProjectWindowDrag(HierarchyProperty, Boolean)
UnityEngine.GUIUtility:ProcessEvent(Int32, IntPtr)
e1_scheer
e1_scheer
Posts: 120, Visits: 1.1K
We've gotten this error as well recently.  We're on unity 2018.4
deidrereaystudios
deidrereaystudios
Another thing we have noticed.
Had a few things come up and not sure if you guys have the same trouble.
We setup some npcs and enemies inside of cc3 with lods
1.)For one the character controller we have needs the fbx of character which does not have LODS set up from cc3 those are on the prefab of made character.
2.) we just copied the lod component and pasted as new on the controlled character or the fbx but then we dont have the character cull
3.) literally tried a dozen things and reached out on different forums and still can not for the life of us get any of the characters to cull. they seem to go through the lods but never cull...
Have you guys tried this or ran into any of this??
Thanks
Posts: 23.1K, Visits: 36.6K
deidrereaystudios (5/12/2020)
Thanks in advance
Hi...
Please report the issue in the Feedback Tracker and the team will investigate. The tracker is monitored directly by the relevant teams and you will get feedback from the team there when applicable. In addition, it allows other users to support your report with the most requested issues/suggestions getting priority.
To use the Feedback Tracker, please click the link below. Thanks.
e1_scheer
e1_scheer
Hi,
I know the answer is well intended but from my personal experience the feedback tracker is where issues go to stand in line
and die a slow death.  I've listed and documented several issues and NONE of them have been adressed.  I have also
used up my quota of upvotes (which is limited to ten I believe).
I am aware that reallusion has their own priorities but at some point real customer support needs to be pushed higher up the
list.  I appreciate all the new tools and applications and the push for ever greater high fidelity results, but not at the cost of getting
existing or basic features working in a stable and consistent way.
Iwan
abranchfie
abranchfie
Reallusion's customer support sucks!  This thread has been going on for around a year now.  When is this going to be fixed?  This is a broken feature.  I had another problem with a content package and it took them over a month to respond only to find out that my issue was a limitation of the package.  Reallution should be more respectful of other people's time and money.
