Dear Character Creator Users, We have now released the 3.1 update for Character Creator 3 which as added numerous new and exciting new features plus bug fixes. However, as always we still need your assistance to help us track down any bugs, glitches or other annoying issues that may still remain.
Important: If you do find any bugs, issues or glitches in Character Creator 3.1, please can you report them first in the Feedback Tracker. Then feel free to discuss the issues in this thread but do try to include a link back to the original Feedback Tracker report or your tracker number. As always it will help us greatly if we can keep all technical issue discussion in the one place (this thread). This will help the development team keep track of any problems. Please do try to provide your full system specifications and a detailed description of the problem when reporting issues. If you can provide steps so we can try and reproduce the problem that will be even better. Many thanks and have fun with Character Creator 3.1.
Last Active: 59 seconds ago
This is the biggest one, IMHO. Been around for quite a while: https://www.reallusion.com/FeedBackTracker/Issue/Transformer-not-correctly-mapping-vertices-for-many-characters-with-larger-necksEssentially there is a neck vertex mapping issue with many of the Daz characters coming through Transformer. This shouldn't be a hard fix since those same verts ARE being accessed (just not correctly).
TonyDPrime
TonyDPrime
Last Active: 10 hours ago
Posts: 3.4K,
Visits: 12.4K
3.1 - Custom Preset Creation Issue Creation of an avatar Preset for both Skin and Morph is Broken: (1) Select Skin&Morph category for Menu-selected "AvatarPreset" (2) Hit "+" button to create a preset (3) Dialogue appears showing preset type to be created (4) When you click "OK" so that preset will be created, nothing is shown, you can not see or access the preset you seemingly just created for Skin&Morph. It is not shown or listed anywhere. It seems to work for all the categories separately, like FullBodyMorph, BodyMorph, Head, Hair, Mouth, Eyes.... But 3.1 does not let you create a working-preset / icon for Skin&Morph (materials and morph).
Hi Tony Skin & Morph preset saving is working for me (anyone else having problems?). I notice from the screenshot you have the eyes selected. Try selecting the avatar and see if it works now. When you choose Full-Character it should save in the "Full Body" folder and Head will obviously save in the "Head" folder. Also, have you tried this after a fresh restart of CC3. It might have been a temporary glitch originally.
TonyDPrime
TonyDPrime
Posts: 3.4K,
Visits: 12.4K
Peter (RL) (9/2/2019) Hi Tony
Hi Peter, I tested again and you are right, as it indeed works after a fresh restart. But, I find it *only* works after a fresh restart. And, I believe I have found what makes it not work in m,y case, because I was not working from a fresh restart. Instead, I am applying individual Presets I made first (ie - skin, eyes, morph, etc), and then trying to create a full-body Skin&Morph preset master (inclusive of these applied sub-presets). In this case, where I apply my individual custom presets first, then creating a Skin&Morph preset does not work. As such a Skin&Morph preset only can be created from scratch after fresh restart... So, the utility is really limited.
TonyDPrime (9/3/2019)
As such a Skin&Morph preset only can be created from scratch after fresh restart... So, the utility is really limited.Thanks for explaining more. We will try to reproduce the problem and check to see if there is an issue that needs fixing.
TonyDPrime
TonyDPrime
Posts: 3.4K,
Visits: 12.4K
I don't know what causes the sub-presets from stopping the Skin&Morph preset from being able to be created, but it also occurs if you load a scene with sub-presets applied to a character. If you load a scene that had a sub-preset applied, the Skin and Morph preset creation tool will not function. It could be the glitch is the sub-preset modifies the scene's code to where it stops the icon part of the Skin&Morph from working.
Now what does work - you can have a fresh restart as you (Peter) mentioned, and start building a Skin&Morph preset from scratch, and it will work. And in this scenario you can either create new additional Skin&Morph presets, or replace the Skin&Morph ones already created with your updates. But - as soon as some sub-preset is applied (morph, eyes, etc), then additional Skin&Morph presets can't be created anymore, and you can't replace an already existing Skin&Morph preset anymore either.
Which, becomes a double whammy because I thought maybe a workaround could be to 1) create a default Skin&Morph preset from scratch in a fresh-restart scene, and then 2) after that apply the sub-presets, and then 3) just replace that respective already-existing Skin&Morph preset I had created in step-1 with a Skin&Morph preset 'replace'. But that does not work either.
So, it's like as soon as you apply a sub-preset, that's it. Skin&Morph ones can no longer be created or replaced. If we could have it where the code allows for the Skin&Morph continues to function this would be great.
BTW - it doesn't matter if you had just the eye or the whole character highlighted, when it does work, the dialogue still works no matter what is selected.
THX!
micabreen
micabreen
Visits: 318
this problem has been with me for 6 months now and no one has even offered a solution... https://forum.reallusion.com/407599/working-with-decals-Help?Keywords=decal%20greysoon as i place a decal a grey box appears on the character cannot get rid of it hide it anything. when i put a actual decal on it will show the texture of course with a grey box around it as well.. see post and hopefully someone up the food chain can assist me . smh
Last Active: 9 hours ago
Posts: 15.7K,
Visits: 30.6K
micabreen (9/11/2019)
this problem has been with me for 6 months now and no one has even offered a solution... https://forum.reallusion.com/407599/working-with-decals-Help?Keywords=decal%20greysoon as i place a decal a grey box appears on the character cannot get rid of it hide it anything. when i put a actual decal on it will show the texture of course with a grey box around it as well.. see post and hopefully someone up the food chain can assist me . smh See my response to a similar post from you here: https://forum.reallusion.com/FindPost422600.aspx.
Magique
Magique
Visits: 1.4K
I am working on a character based on Ayaka. I converted it to CC3 and then Game Base. All was working fine until I tried to apply the Game Eyes. Applying Game Teeth worked fine, but when applying Game Eyes, both eyes suddenly get jumbled up in the left eye socket. See attached image for what it looks like. I will leave the eyes as-is for now, but would like to convert to Game eyes when this bug is fixed. I submitted this via Feedback tracker Issue #6274
