StyleMarshal
StyleMarshal
Posts: 5.8K,
Visits: 14.3K
Ok , I need the UE4 files , cause there is the issue. 1. You can zip the project and send it by Wetransfer as a PM  or , if its too big and you won't send me the project , then send me the Character only. I need the Character Folder and the CC_Shader Folder. Put this in a. Zip or .rar and send it via wetransfer as PM. I don't know your Characters Name , so I put a Question Mark.
StyleMarshal
StyleMarshal
Posts: 5.8K,
Visits: 14.3K
nealtucker (8/24/2020) Thanks Bassline, Another question from others with a longer .....more than a week.. with working with live link. So far I have found that I can get live link working fine, then for some unknown reason, the link breaks and will not work or rather, it says the link is working with green dot in IC and connected in UR but no matter what I do the only way is to delete the imported character in the UR IC folder and do a new transfer. Point is, have others found the same problems, or is it most likely in my case user error? Thanks for any insight with this as it will really help moving forward. ie what I should not do? N. The names of the Character are identical in IC and UE4 , right? Are you using Ue4.25.3? There could be a few Blueprints with the same name , select the Blueprint in your RLContent folder and tick the arrow that I have marked.
charly Rama
charly Rama
Posts: 1.9K,
Visits: 17.3K
I sent to you all files Bassline.
StyleMarshal
StyleMarshal
Posts: 5.8K,
Visits: 14.3K
yepp , got it...did send you back a PM :-)
nealtucker
nealtucker
Visits: 1.3K
Thanks, I'll make sure the names are exactly the same in both, and I now understand that selecting something and clicking the arrow will load that selection. maybe I missed this vital bit as I have dragged numerous meshes on to the stage until I got one to work, I'm sure I dragged the blueprint one at one time and this worked while the other did not, so now I'll only drag the one with the two little figures in the icon, maybe it or I got confused...more likely it's me, I love the IC -UR -CC marriage if I can get proficient at it, it will stop my user errors and problems. thanks
--------------------------------------------------------------------------------------------------------------------------------------- View my latest Iclone project THEY ARE HERE Renegades versus the overlords
StyleMarshal
StyleMarshal
Posts: 5.8K,
Visits: 14.3K
Mr Charly , the guy with dynamic hair :DHere it looks quite well :  You are working with UE4.25.3 , right? And you are working with an old CC_Setup Plugin : (1.04) Use the newest one (1.1)  You can find it here :
charly Rama
charly Rama
Posts: 1.9K,
Visits: 17.3K
thank you Bassline. I've followed all things, but this is the problem, Without my big ocean scene, it gives that, all thing okay  And when I insert the avatar with my big ocean and island, bim, squares
StyleMarshal
StyleMarshal
Posts: 5.8K,
Visits: 14.3K
Ok , then please check this here : 1. Do a rebuild. 2. Does it look ok when you render? 3. Check this: (try the medium setting)  4. Check this : what LOD is the character mesh? How does the character look after you recompile the mesh lod (a setting available on the mesh panel - when viewing the character mesh, under the LOD settings)?
charly Rama
charly Rama
Posts: 1.9K,
Visits: 17.3K
And I took another map and no squares Aaaaahhhh unreal unreal....
StyleMarshal
StyleMarshal
Posts: 5.8K,
Visits: 14.3K
Which map makes the trouble? (Name of the map?)
