iProp Rigid Body Simulation
Posted By troycarpenter7 7 Years Ago
troycarpenter7
troycarpenter7
Veteran Member (606 reputation)Veteran Member (606 reputation)Veteran Member (606 reputation)Veteran Member (606 reputation)Veteran Member (606 reputation)Veteran Member (606 reputation)Veteran Member (606 reputation)Veteran Member (606 reputation)Veteran Member (606 reputation)
Last Active: 7 Years Ago
Posts: 24, Visits: 84
iClone didn't crash this time. The links phased through each-other but I think this is do to poor placement of the point-to-point constraints.
As you should be able to see the links separated in some places.
I don't understand the placement of the point-to-point links. Where should I place each end?
Also where do I put the dummy I attach everything to? I was unsure on this part.
troycarpenter7
troycarpenter7
Here is that picture that was meant to be attached. I seem to be having some issues uploading an image to the forums.TinyPic Link
Last Active: 6 days ago
Posts: 5.3K, Visits: 16.8K
Better post the prop itself than explaining :)
I'll do it a bit later....
OK, here it is. Not perfect, but pretty much believable.
If you need it to stay on the ground, add a static plane to the ground and set its collision margin to 0.01
FLAIL.zip (82 views, 256.00 KB)
