mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
First in my Iclone the UV_Setting is broken. It only works in 3DXchange.  Second , the opacity is a nightmare , Impossible to have descent reflection with semitransparent mesh in PBR mode and impossible to have a Glowing object behind a semitransparent object.
Skuzzlebutt
Skuzzlebutt
Visits: 8.6K
the first question: you have to hit apply for the changes to take effect there isn't anything greyed out in your screenshot
mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
I used Iclone since 2011 Kipster and I know I have to hit Apply ;)
But if you say that in your Iclone 7.41.2525.1 it works , this would mean that it's my iclone.
Skuzzlebutt
Skuzzlebutt
Visits: 8.6K
sorry, im in 7.3 until projects are complete the glow and uv work in 7.3 so, good thing i didnt upgrade.
mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
Digging deeper into my Glow issue ; the glow works if there is no opacity texture.Glow is broken behind a semi transparent mesh if there is an opacity texture. I hope I would have saved you time....
mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
And I found how to fix.... Activate Alpha threshold !
Posts: 23.1K,
Visits: 36.6K
mtakerkart (5/21/2019) First in my Iclone the UV_Setting is broken. It only works in 3DXchange.
UV Settings appear to be working fine for me in iClone 7.41. Can you record a short video showing the issue as you did with the other problem? Thanks.
mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
Hi Peter , Here it is:
Last Active: 11 hours ago
Posts: 5.3K,
Visits: 16.8K
There is definitely a bug in the iClone 7 handling UV. Here is sphere shaped figure decently unwrapped in Blender and imported into 3DX  Now I have sent it to iClone and all looks good:  But not until I switched to wire-frame view:  No wonder iClone is having a problem with different types of UV unwrap. The same object imported through 3DX 6 to iClone 6 shows no sign of problem and changing UV types is working fine.
Posts: 23.1K,
Visits: 36.6K
Many thanks. This has now been passed to the dev team to investigate. Please do remember the best way to report suspected issues is using the Feedback Tracker. The tracker is monitored directly by the relevant departmental teams who may give additional feedback. Thanks.
