mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
Thank you Peter ,
I sent you a private message.
Posts: 23.1K,
Visits: 36.6K
mtakerkart (5/21/2019)
First in my Iclone the UV_Setting is broken. It only works in 3DXchange.  UPDATE: If you are still having these UV issues in iClone, can you let us know if the issue is with all props or just some custom props? If the latter could you please let us have the prop shown in your video so we can further test the issue. You can send me a private message with a download link if you don't wish to post it publically. Thanks.
Posts: 23.1K,
Visits: 36.6K
4u2ges (6/2/2019) There is definitely a bug in the iClone 7 handling UV.
Hi 4u2ges... I have also passed on your feedback as well. :)
Posts: 23.1K,
Visits: 36.6K
Many thanks. This has now been passed to the dev team to investigate. Please do remember the best way to report suspected issues is using the Feedback Tracker. The tracker is monitored directly by the relevant departmental teams who may give additional feedback. Thanks.
Posts: 5.3K,
Visits: 16.8K
There is definitely a bug in the iClone 7 handling UV. Here is sphere shaped figure decently unwrapped in Blender and imported into 3DX  Now I have sent it to iClone and all looks good:  But not until I switched to wire-frame view:  No wonder iClone is having a problem with different types of UV unwrap. The same object imported through 3DX 6 to iClone 6 shows no sign of problem and changing UV types is working fine.
mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
Hi Peter , Here it is:
Posts: 23.1K,
Visits: 36.6K
mtakerkart (5/21/2019) First in my Iclone the UV_Setting is broken. It only works in 3DXchange.
UV Settings appear to be working fine for me in iClone 7.41. Can you record a short video showing the issue as you did with the other problem? Thanks.
mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
And I found how to fix.... Activate Alpha threshold !
mtakerkart
mtakerkart
Posts: 3.2K,
Visits: 29.2K
Digging deeper into my Glow issue ; the glow works if there is no opacity texture.Glow is broken behind a semi transparent mesh if there is an opacity texture. I hope I would have saved you time....
Skuzzlebutt
Skuzzlebutt
Visits: 8.6K
sorry, im in 7.3 until projects are complete the glow and uv work in 7.3 so, good thing i didnt upgrade.
