Another BUGS ??
https://forum.reallusion.com/Topic413633.aspx
Print Topic | Close Window
By mtakerkart - 7 Years Ago
First in my Iclone the UV_Setting is broken. It only works in 3DXchange.
https://forum.reallusion.com/uploads/images/489a7e23-87a4-49f9-ba05-14a2.jpg
Second , the opacity is a nightmare , Impossible to have descent reflection with semitransparent  mesh in PBR mode and impossible to have a Glowing
object behind a semitransparent object.
By Skuzzlebutt - 7 Years Ago
the first question:
you have to hit apply for the changes to take effect
there isn't anything greyed out in your screenshot
I used Iclone since 2011 Kipster and I know I have to hit Apply ;)
But if you say that in your Iclone 7.41.2525.1 it works , this would mean that it's my iclone.
sorry, im in 7.3 until projects are complete
the glow and uv work in 7.3
so, good thing i didnt upgrade.
Digging deeper into my Glow issue ; the glow works if there is no opacity texture.Glow is broken behind a semi transparent mesh if there is an opacity texture. I hope I would have saved you time....
https://forum.reallusion.com/uploads/images/86ea7049-cc75-4c17-89fc-397c.jpg
https://forum.reallusion.com/uploads/images/e1c6007b-85e1-4fb0-b431-6866.jpg
And I found how to fix.... Activate Alpha threshold !
https://forum.reallusion.com/uploads/images/0a242b5a-c679-4627-8f19-9bae.jpg
By Peter (RL) - 7 Years Ago
mtakerkart (5/21/2019)
UV Settings appear to be working fine for me in iClone 7.41. Can you record a short video showing the issue as you did with the other problem? Thanks.
Hi Peter , Here it is:
By 4u2ges - 7 Years Ago
There is definitely a bug in the iClone 7 handling UV.
Here is sphere shaped figure decently unwrapped in Blender and imported into 3DX
https://forum.reallusion.com/uploads/images/74df0ab0-c10a-4056-9c90-7c32.jpg
Now I have sent it to iClone and all looks good:
https://forum.reallusion.com/uploads/images/6fdae174-98d7-42e9-87b4-c373.jpg
But not until I switched to wire-frame view:
https://forum.reallusion.com/uploads/images/f8147916-66f0-4569-a464-bd79.jpg
No wonder iClone is having a problem with different types of UV unwrap.
The same object imported through 3DX 6 to iClone 6  shows no sign of problem and changing UV types is working fine.
mtakerkart (5/29/2019)
https://www.youtube.com/watch?v=BwP9VlUhKZs
Many thanks. This has now been passed to the dev team to investigate.
Please do remember the best way to report suspected issues is using the Feedback Tracker. The tracker is monitored directly by the relevant departmental teams who may give additional feedback. Thanks.
4u2ges (6/2/2019)
Hi 4u2ges... I have also passed on your feedback as well. :)
UPDATE:
If you are still having these UV issues in iClone, can you let us know if the issue is with all props or just some custom props? If the latter could you please let us have the prop shown in your video so we can further test the issue. You can send me a private message with a download link if you don't wish to post it publically. Thanks.
Thank you Peter ,
I sent you a private message.
