I think I have trouble saying what I mean these days
But that's OK, its why I said demonstrations rather than tutorials.
Another one I got from you was
hereIts not so much what your making that got to me for assistance. Its more some of the processes you do that has improved my time of making things in my methods.
For example in the one you posted in the link I added here the way you filled the hole in the object when you cut it in half was something I wasn't aware of.
I normally select a few vertexes and press F to fill them with a face and repeat it until I get the shape I want. But the way you did it I wasn't aware of and that has helped my timeline while making things
In this one its the way you made the multi circle edges rotating up (sorry I have difficulty using correct words).
I do that sort of thing by creating multiple circles, moving them up above each other removing a vertice from each of them and then merging a vertice from one to a vertice in the one above it.
I then select a vertice on each one and then pull them up a little. Repeat that until I get the shape you made. Takes me a several minutes to do it that way.
But the addon you showed has opened my mind to improve my timing and these are the things I am thanking you for
i7-3770 3.4GHz CPU 16 GB Ram
GeForce GTX1080 TI 11GB
Windows 10 Pro 64bit
5 Years Ago by
Delerna
