Change Sky Color
Posted By lvanvalk 7 Years Ago
lvanvalk
lvanvalk
Posts: 75, Visits: 141
I need to make the sky gradually start changing color half way through the scene. Initially I created three clips, one with blue sky one with red sky then pulled them into my video editing program and used a cross dissolve; then had the character on top in a green screen. That worked fine until I added FX to the character and the FX didn't show up on the green screen. So instead of three separate clips I need everything in one. That means changing the sky color within the scene. I tried pulling in a second sky to turn on and off but when I pulled in a new sky it deleted the first. I also want it to be gradual not immediately turning on and off.
Everyone has always been so helpful in my learning, I look forward to your advise. Thank you.
Posts: 15.8K, Visits: 31.4K
Instead of using a sky, you could use a sky-dome prop.
There is one called 360 sky under Props > 3D Space. I'm not quite sure if the UV mapping is the same as for the sky, but it would allow you to animated the texture or use a video.
https://forum.reallusion.com/uploads/images/c34511d0-240b-4cff-b771-6530.png
Remember to turn all shadows off for the sky dome prop and to set self-illumination to 100%.
lvanvalk
lvanvalk
Thank you for your quick reply. I will check it out.
Skuzzlebutt
Skuzzlebutt
Posts: 582, Visits: 8.6K
if your using iclone 7 there is a much better option!~
https://forum.reallusion.com/uploads/images/6f171f62-57de-4bf4-8e87-2cc5.gif
the ibl image in your visual tab allow s you to change skies
at any or many points in the timeline
it will also affect the lighting on your models....
you can adjust the fade time in the timeline/project/ibl image
by moving the left handle (like motion blending)
just simply move your timeline indicator, press add new ibl clip and click inside the ibl image window
https://forum.reallusion.com/uploads/images/218be128-7cb9-4444-9caa-0b88.png
lvanvalk
lvanvalk
That is so cool. Thank you!
