Cartoon Animator 4.0 - Known Issues
Posted By Ola(RL) 7 Years Ago
Ola(RL)
Ola(RL)
Distinguished Member (22.2K reputation)Distinguished Member (22.2K reputation)Distinguished Member (22.2K reputation)Distinguished Member (22.2K reputation)Distinguished Member (22.2K reputation)Distinguished Member (22.2K reputation)Distinguished Member (22.2K reputation)Distinguished Member (22.2K reputation)Distinguished Member (22.2K reputation)
Last Active: 6 Years Ago
Posts: 238, Visits: 2.4K
Reallusion did our best to provide you with a stable Cartoon Animator 4.
However, there are some issues can not to processed without effect the launch date.
https://forum.reallusion.com/uploads/images/5042e8da-8e51-4f00-9973-04f3.jpg
Here are the known issues and related workaround.
  • Issue: The Motion LIVE 2D for LIVE FACE (iPhone APP) does not support 1.0.3 version.
    • Workaround: Please update the LIVE FACE (iPhone APP ) version to 1.0.5. from iPhone App store.
  • Issue: The body has a little glitch when using body profile with LIVE FACE motion capture.
    • Workaround: Adjust the Strength value from body profile.
  • Issue: Face3D Tracker does not support 4K large fonts.
    • Workaround: Reduce resolution or adjust font size.
  • Issue: Missing the head of character when importing the character.
    • Workaround: Please right click to remove object animation, and check the default sprite settings in Sprite Editor.
  • Issue: Some character outlines appear blurry after launching PSD editor.
    • Workaround: adjust exporting image scale in PSD options.
  • Issue: Incorrect size of accessory after updating PSD character.
    • Workaround: Re-scale the accessory to fit with the character head.
  • Issue: Low performance during preview of the 360 Head Create when using minimum Mac system requirements.
    • Workaround: Ajust low Max Real-time Map Size in preference settings, or upgrade system requirement.
  • Incorrect direction when tracking head by mirror function and body recording at the same time.
    • Workaround: Separate recording with head and body and use the 2D Motion Key Editor to edit body motion.
  • Issue: Applying motions would not follow previous motions when replacing character and opening the option of Align to Previous Motion.
    • Workaround: right-click to re-align motion within the timeline clip.
  • Issue: Attach status could not cancel correctly when right clicking Attach function in Composer Mode.
    • Workaround: switch to Select Mode (HotKey: 1) for cancel Attach status in Composer Mode.
  • Issue: Incorrect layer order display in Stage Layer Editor.
    • Workaround: Please try to re-order the layer order in the Composer Layer Manager.
Image guides of the workaround will be provided in the mid of May.
Threaded View
Threaded View
Forum Post Cartoon Animator 4.0 - Known Issues By Ola(RL) ( 7 Years Ago )
Forum Post But the biggest issue isn't listed here - it crushes all the time and... By kiberdan ( 7 Years Ago )
Forum Post [quote][b]kiberdan (5/21/2019)[/b][hr]But the biggest issue isn't... By Peter (RL) ( 7 Years Ago )
Forum Post Hi, I have the Live Motion 2D plugin, but I don't know how to install... By Shazak ( 7 Years Ago )
Forum Post [quote][b]mosheshazak (6/12/2019)[/b][hr]Hi, I have the Live Motion 2D... By Peter (RL) ( 7 Years Ago )
Forum Post [quote][b]mosheshazak (6/12/2019)[/b][hr]Hi, I have the Live Motion 2D... By Peter (RL) ( 5 Years Ago )
Forum Post I'm curious--are you still using CTA 3? I had to start using it... By OldRoz ( 7 Years Ago )
Forum Post I'm using a Mac and having the same crashing issues. I'm working with... By chris.dabbs87 ( 7 Years Ago )
Forum Post [quote][b]chris.dabbs87 (6/10/2019)[/b][hr]I'm using a Mac and having... By Peter (RL) ( 7 Years Ago )
Forum Post Chris, I would not buy this software, at least at the present time. I... By OldRoz ( 7 Years Ago )
Forum Post [quote][b]OldRoz (6/11/2019)[/b][hr]I doubt that a solution will be... By Peter (RL) ( 7 Years Ago )
Forum Post issue: Elastic Motion Editor - Motion Curve cannot be processed By nemesis14 ( 7 Years Ago )
Forum Post WILL all the bug fixes listed on the front page be fixed and upudated... By niceblinkluck ( 7 Years Ago )
Forum Post Just bought and installed Cartoon Animator 4 in my Mac (OSX 10.14.5)... By loliaudio ( 7 Years Ago )
Forum Post [quote][b]loliaudio (7/8/2019)[/b][hr]Just bought and installed... By Peter (RL) ( 7 Years Ago )
Forum Post I am having repeated crashes on shut down and sometimes on start up.... By Derson.Digital ( 7 Years Ago )
Forum Post I am wanting to enter the contest due by 10/31, I downloaded the trial... By Aysterix ( 7 Years Ago )
Forum Post Hi I just came across the issues listed above, re crashes. I have... By woodie50 ( 6 Years Ago )
Forum Post Hi Woodie Sorry to hear you are experiencing crashes. This is of... By Peter (RL) ( 6 Years Ago )
Forum Post My problem is not here, Cartoon Animation 4 crashes when ever I try to... By abdellatif.ahmed ( 5 Years Ago )
Forum Post I cannot even get my paid version of CA4 to load on my Mac. I can... By angela_223047 ( 5 Years Ago )
