paulm_872026
paulm_872026
Visits: 45
I had the same problem and traced it back to where I'd pressed 'Convert to Accessory'. When you make it an accessory you can't...use it as an accessory?? When I didn't press that I could save it as..an...accessory? Not that I'm really confused now or anything.
Posts: 23.1K,
Visits: 36.6K
ricardopereirafilho (1/2/2020)
From your screen shot it looks like you are trying to save in the Content template folder. Try clicking on the custom tab to see if this then allows you to save there. Geoff.
Yes, I tried the custom tab also. Same problem. I installed my Reallusion softwares in another computer, with the content folders in drive D: and the same issue happens with CC3 Spending some energy a few nights on this :doze: The issue may be caused by a permissions problem accessing the custom content folders. Please try the following: 1. Ensure you are logged into your computer as an Administrator. To check in Windows 10 go to Start > Settings > Accounts.
2. Please check that you have read & write access the "Custom" content folder on your D: drive. Please refer to the page below for help on checking this. Thanks.
Ricardo Pereira Filho
Last Active: 9 Months Ago
Visits: 34
Zeronimo
Zeronimo
Last Active: 6 Months Ago
Visits: 19.3K
how to save custom cloth to CC3 See from 2'35 how to save the cloth - you must first select your cloth (not the avatar) - place yourself in the right directory (custom …)
Galfridus
Galfridus
Visits: 2.2K
Hi guys! I have the same problem. Cant save my own contents. I have just update CC3.21.2423.1 Pipeline version. My contents folders are in drive D: Any suggestions?  From your screen shot it looks like you are trying to save in the Content template folder. Try clicking on the custom tab to see if this then allows you to save there. Geoff.
Visits: 34
Posts: 15.8K,
Visits: 31.4K
garidian (3/30/2019) I have the same issue. After reinstall it works for one day and than the same issue in Character Creator. If I export the Charakter to Iclone I be able to save there. I bought the pipeline Version of CC. With this bug it is complete useless for me. If this is not fixed very fast i must check for refund this useless CC.
If it were a bug it would affect everybody, which is not the case. I, for one, can save fine. To get assistance for your particular situation, your best cause of action is to contact support at: https://www.reallusion.com/CustomerSupport/UserEx/QForm.html.
garidian
garidian
Last Active: 6 Years Ago
Visits: 147
micabreen
micabreen
Visits: 318
i tried to run as admin and same thing i am gonna try to reinstall i guess cause this is really annoying i want fast access to the things i make seems like a complete reinstall did the trick
Posts: 15.8K,
Visits: 31.4K
Where is your Custom folder located on your system? This looks like an access problem with the folder. One thing you could try is to run CC as administrator and see if you can save.
