ramonafirst
ramonafirst
Last Active: 6 Years Ago
Visits: 29
I'm frustrated because I can't talk to anyone. I replaced sprites to create a new character. For some reason the lefthand is disconnects when I go to the stage mode to animate ate the character. I tried deleting the new sprite and reloading. But that didn't work. I tried reposition it and the bone but nothing.
Posts: 1.0K,
Visits: 9.9K
Part of the left hand must overlap the arm/forearm. The bone connects the hand to the arm/forearm. If you do this correctly, it will not get separated.
 YouTube Tutorials Here
coolhewitt24
coolhewitt24
Visits: 17.5K
Hi Ramon, I encountered a similar problem when I first started using the software. You need to make sure the red dots are directly on top of the joints. You can also make sure the bones in the middle of the sprite. I made a lot of mistakes when I was first starting out. I've gotten a lot better now. https://www.youtube.com/channel/UC-_ReB1kqKNr-XIOEZggUWA?view_as=subscriber
