By ramonafirst - 7 Years Ago
I'm frustrated because I can't talk to anyone. I replaced sprites to create a new character. For some reason the lefthand is disconnects when I go to the stage mode to animate ate the character. I tried deleting the new sprite and reloading. But that didn't work. I tried reposition it and the bone but nothing.
By vepop - 7 Years Ago
Part of the left hand must overlap the arm/forearm. The bone connects the hand to the arm/forearm. If you do this correctly, it will not get separated.
By coolhewitt24 - 7 Years Ago
Hi Ramon, I encountered a similar problem when I first started using the software. You need to make sure the red dots are directly on top of the joints. You can also make sure the bones in the middle of the sprite. I made a lot of mistakes when I was first starting out. I've gotten a lot better now. https://www.youtube.com/channel/UC-_ReB1kqKNr-XIOEZggUWA?view_as=subscriber
