Posts: 23.1K,
Visits: 36.6K
iClone 7.41 has now been released. Please see the first post in this thread for instructions on how to report any bugs or issues you may find in the new update.
Posts: 15.8K,
Visits: 31.4K
m_koshi (1/22/2019)
Alpha has big square noise  In animation rendering, a large square noise is placed on the mask alpha. I tried various tests such as TGA sequence, PNG sequence, Alpha only MPG, but all the same phenomena occur. This large square noise is about 100 x 100 pixels, which is a little bit thinner than black 100% and occurs at random positions, and this condition occurs randomly every ten-several frames. so it may not be noticeable. This was due to a noise effect being added by default to suppress color banding. Check Effects under Visual, where it can be disabled. This will solve your problem. BTW, in iClone 7.41 this is no longer the default but added as a rendering option.
Does anyone remember where iClone and Iray put TEMP files on the C: Drive?
a) My sky suddenly turned white for no apparent reason. b) My C: drive only has about 65MB free... yesterday it had several GB free
I think the "In-session" Iray render has filled my C: drive.
I have an urgent non-computer errand to do, gotta run.
Posts: 15.8K,
Visits: 31.4K
The default I believe is %APPDATA%\Local\Temp\iClone7Temp. I have my iClone temp directory on a different drive as my system drive is "only" a 512 GB SSD.
TonyDPrime
TonyDPrime
Posts: 3.4K,
Visits: 12.4K
This is a FBT I made today regarding the 2D Video Image Layer. Basically in 7.3x and before, you were able to render the 2D Video Image Layer video as part of the timeline, as in each frame that passed on the timeline would mean the next frame in the video would be rendered. But in 7.41, it only renders the first frame of the video in the 2D Image Layer perpetually on the timeline.
Ie, frame 1 on timeline = frame 1 of video on the 2D Image Layer, and frame 20 on timeline = frame 20 of video on the 2D Image Layer. (correct)
But in 7.41, it only renders the first frame of the video in the 2D Image Layer perpetually on the timeline. Ie, frame 1 on timeline = frame 1 of video on the 2D Image Layer, and frame 20 on timeline = frame 1 of video on the 2D Image Layer. (incorrect)
Posts: 23.1K,
Visits: 36.6K
Dragonskunk (1/21/2019) While I'm at it I'll add to Feedback Tracker that [ Merge Clips ] Doesn't work. When you disable [ Clip Auto Extend ] That is no problem there. But when you need to merge the clips it adds keyframes, it adds unwanted animations, it also includes invisible keyframes (pose from avatar changes but nothing visual on the timeline), it basically does not reproduce the existing animation into one clip. It's a mess. Hi Dragonskunk Just to let you know this has been confirmed as a bug and we plan to fix it hopefully in the next update.
dpolcino
dpolcino
Last Active: 7 Months Ago
Visits: 319
The spring feature seems to have stopped working for me (version 7.41.2525). It worked fine about a month ago, I used it extensively. Now I'm doing the same thing and getting no results. This is true in standard "rib twist" springs in CC3 and older iClone characters, as well as my own simple props. But they work great in 3D Xchange.
Dave Corwin Polcino Reallusion Web Series: ADULT ANIMATION SERIES Company: Noise and Vision
Dragonskunk
Dragonskunk
Visits: 1.4K
I'm getting problems with blow out. This has happened to me 3 times now. I made dozens of scenes using this skin texture. I saved it as a material so it's the same texture but once I applied the material skin.iMtl the scene gets blown out like a nuclear explosion. I load this tweaked avatar that is replacing the old one, I previously saved all materials of the old so that I can transfer them to the new avatar, and I load all the textures but when it came to the skin then it blows out. The only thing different about the skin than all the other materials it was tweaked with the Adjust Color. I adjusted saturation to +100 before saving it as that was the ideal setting for the skin. The blow out doesn't go away no matter what I did, I deleted the material texture, made every setting to black, turn off all Visual effects off, and tried changing GI settings even changing the adjust colors settings to the palest values. The only thing that stopped it from blowing out was to make the opacity less than 100%... But that is undesirable. I suspect that there's a bug with Adjust Color, but I want to see if others are getting the same problem as me.
