Visits: 62.6K
You have to uninstall before you can reinstall. To be totally clean, also do this after you uninstall: Check this directory for any iClone leftovers and delete them: C:\Program Files\Reallusion Find this directory: C:\Users\your name\AppData\Local\Temp Delete this folder: iClone7Temp Note that AppData is a hidden folder, and you may need to set "Show hidden files and folders" for Windows Also note that "your name" is your user name on your computer. Your content folders will be safe. You can just go with the defaults for installation.
toystorylab
toystorylab
Posts: 4.6K,
Visits: 29.9K
Not sure to go for it. As API is way above my grasp and the fixes not really needed for the moment i will wait to see if there are some bugs delivered... To all the API cracks in here: time to start working on some handy practice applications which will make all these "mission impossible"s possible ;) And as i have no clue what API can make possible, i have not a wishlist yet, but i'm looking forward to the results. :w00t:
Rottadamic
Rottadamic
Visits: 982
and that was crash number 4 :( man this version is unstable :crying:
Rogue Anime
Rogue Anime
Visits: 3.4K
Friends - I want to thank Mike & Steve for all their help, but alas, I have uninstalled, downloaded and RE-installed my iClone 7 and I STILL cannot open the program! I was having no problems until I installed this 7.4 patch - now my iCLone is USELESS! Is there a way to uninstall this and roll it BACK to version 7.3? I am dead in the water here and VERY unhappy.
Merry Christmas, Reallusion - Thanks for the crippling 'update' - now - GIVE ME BACK MY iCLONE! (please! lol) ~V~
Val RogueAnanda
Visits: 22.1K
Val, We are *just* about to eat our Christmas Eve dinner (big turkey -- 26lbs -- and so much alcohol there's no way I'll be back online) but did you do all that Rampa said above at the top of this page? There's no reason you can't install 7.3 -- if it's not working there is something wrong most likely with your hub. Note: you can download the direct installs of 7.3, so that'a another alternative, but first things first -- get rid of ALL traces of iClone from your machine using Rampa's outlined procedure (hell - the eggnog is affecting me even now -- I've retyped this paragraph three times now). Okay, sorry, will be offline until either tomorrow morning or MUCH later tonight. But don't despair!
Visits: 62.6K
If it just really does not want to work, you can always roll your system back to an earlier restore point.
Did you go ahead and download the latest full installer from your account? That will be 7.4, but it worked for me. Restart after your install, for good measure!
Rogue Anime
Rogue Anime
Visits: 3.4K
Rampa (12/24/2018)
You have to uninstall before you can reinstall. To be totally clean, also do this after you uninstall: Check this directory for any iClone leftovers and delete them: C:\Program Files\Reallusion Find this directory: C:\Users\your name\AppData\Local\Temp Delete this folder: iClone7Temp Note that AppData is a hidden folder, and you may need to set "Show hidden files and folders" for Windows Also note that "your name" is your user name on your computer. Your content folders will be safe. You can just go with the defaults for installation. Rampa & Mike - Thank you so much for your time and for your responses! I tried this, but it did not work. I followed yours & Mike's instructions. I restarted after uninstall & temp folder deletion, as well as after re install. I tried this 3 times before I gave up - no soap! I am STILL getting the error @the startup banner and it closes the program before it can start - I will have to roll back to 7.3 with your help, as I haven't done that rollback thing before. Merry Christmas, and thanks again for your time. ~V~
Val RogueAnanda
Visits: 62.6K
Before that, try un-installing plugins. If you have Motion Live, un-install that first. You can reinstall a fresh version later. Hopefully you have a recent restore point, if you end doing that. Anyway. Have a look here: https://support.microsoft.com/en-us/help/12415/windows-10-recovery-options
luke (RL)
luke (RL)
Group: Power Developer
Visits: 5.6K
Hi, Rogue Anime
Sorry for this new update caused you can't run iClone. Did you install the Curve Editor before? If yes, please go to [Your iClone location]\\Bin64\Plugin\ then delete the file called "ICCurveEditor.dll" and try to restart the iClone again.
thanks
argus1000
argus1000
Visits: 11.6K
I can't even install the new iclone 7.4 update. As soon as the splash screen appears, there's another window that pops up, telling me that iclone has to close. Repeat ad infinitum. I had to restore my system. I was hoping to be able to work with a repaired timeline, but no luck.
