[ iClone 7.4 NEW RELEASE ] Python Open API is Available!
Posted By Tony (RL) 8 Years Ago
3
4
5
6
7
10
3dtester
3dtester
Posts: 999, Visits: 2.2K
Ok, it works using the USB method!!
So there may be some issue with the Wi-Fi.
Very strange, since i haven't changed anything on my router or the phone.
3dtester
3dtester
Hi Mike, i understand your statement.
But what could i do wrong with that setup?
- Reinstall iClone and the plugins with the newest versions
- Connect phone to Wi-Fi, start the live face app and check the IP address (pingable)
- Load and select a character, type the IP address into the live face plugin with port :999
- Click on the green circle, nothing happens
There's not even a message that it couldn't connect.
I can the try the USB method.
Posts: 9.2K, Visits: 22.1K
Live Face is working fine for me with 7.4, so I suspect you just need to get it and the plugins installed correctly.
3dtester
3dtester
Is there a way to find out what happens when the live face module tries to connect?
I couldn't find any log file and the program obviously doesn't support command line options.
RL please provide download links for the older versions.
It want to switch back to 7.3 in the meantime. Could skip the python API for now.
No one should be forced to use a new release until it is stable.
3dtester
3dtester
Peter (RL) (12/27/2018)
3dtester (12/27/2018)
Since i installed the 7.4 patch, Live Face is no more working.
There is no error message, it just doesn't connect.
I have already re-installed iClone, the motion live plugin and the live face profile.
I believed that it was a patch issue and the full 7.4 installer would fix it.
So, unfortunately i have overwritten the 7.3 installer.
This is very frustrating...
Do you have the latest iClone 7.4 build which is 7.4.2426.1? If you have not installed this yet, please do so as a matter of urgency.
Do also  make sure you have updated Motion Live to the latest version. Both the Curve Editor and Motion Live need updating for 7.4. Please check the Reallusion Hub for latest updates.
Yes, i used the latest patch. This was my fault: installing the latest two iClone 7.4 patches, without any need!
Now i am on a death road it seems.
Uninstalled iClone and all plugins, downloaded all the full installers and reinstalled everything.
No success.
Would it be possible to provide me a download link for the iClone 7.3 installer + the plugins which are compatible with this version?
(Somehow i have the feeling that this issue has something to do with the new python features)
Posts: 23.1K, Visits: 36.6K
3dtester
3dtester
wildstar (12/26/2018)
'm just using all reallusion plug ins. faceware, perception neuron, curve editor. popcorn fx .. and so on. and my project is quite complex in the part of motion layers and keyframing, so the crashes are randoms and frequent, I will edit something in the curve editor, iclone crash, I will use the faceware iclone crash, but this is totally random, now I am using the faceware and its not  crashing, but I know it can crash anytime. and when it crashs. I already know that I need to restart windows.
Wildstar - As you seem to be having additional issues not being experienced by anyone else, please can you contact Technical Support and supply your system dxdiag.txt. Thanks.
sonic7
sonic7
Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)Distinguished Member (14.2K reputation)
Posts: 1.7K, Visits: 19.4K
Mmmmm sluggish eh? Can anyone successfully *sample* an Avatar's motion layer using vers 7.4?  ie: do a "Sample All Parts". The motion needs to run the full 1800 frames on the timeline - just record an uninterrupted 1800 frames using the Motion Puppet's 'Basic Walk'. Then perform "Sample All Parts". Does it struggle a lot more than usual - or is it my imagination ? ....
Presuming you're successful, - how long does it take to arrow to beginning |< or arrow to end >| ? ie: shunting directly back & forward between first and last frames of this project, using the start and end keys? Instant? or delayed ....
Please be patient with me ..... I don't always 'get it' the first time 'round - not even the 2nd time! :(  - yikes! ...
MSI GT72VR Laptop, i7 7700HQ 4-Core 3.8 GHz 16GB RAM; Nvidia 1070, 8GB Vram iClone-7.93  3DXChange Pipeline 7.81  CC-3 Pipeline 3.44  Live Face  HeadShot  Brekel Pro-Body  Popcorn FX  iRAY  Kinect V2  DaVinci Resolve17  Mixcraft 8.1
wildstar
wildstar
Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)Distinguished Member (8.8K reputation)
Posts: 1.2K, Visits: 5.1K
now one more faceware crashing iclone, i just go to restart windows and all goes to work again , for some hours.
3
4
5
6
7
10
