How can i create a slider only for the head in cc3 ???
Posted By hj 8 Years Ago
3
hj
hj
Distinguished Member (29.8K reputation)Distinguished Member (29.8K reputation)Distinguished Member (29.8K reputation)Distinguished Member (29.8K reputation)Distinguished Member (29.8K reputation)Distinguished Member (29.8K reputation)Distinguished Member (29.8K reputation)Distinguished Member (29.8K reputation)Distinguished Member (29.8K reputation)
Posts: 3.5K, Visits: 18.7K
https://forum.reallusion.com/uploads/images/540d1e52-cd66-4df5-9652-42e0.jpg
If i create a Head-Slider in CC3 and i use the head-slider, the hole bdy will change.
https://forum.reallusion.com/uploads/images/fd27a7d8-84e2-4d7e-b7cf-0ede.jpg
https://forum.reallusion.com/uploads/images/14396af9-ef73-467f-8142-59c4.jpg
But i want only changing rhe Head.
What can do to get this ???
Hans Jörgen
Fehler gehören zum Leben.
Was zählt, ist, wie man auf Fehler reagiert
Niki Giovanni
https://forum.reallusion.com/uploads/images/1a2f83b8-b491-4e74-bf8b-6a98.jpg
Posts: 23.1K, Visits: 36.6K
Hi HJ
Just make sure the Body is "Reset" first before saving the Head morph slider. Then it will not affect the body when applied.
You can then do the same to save the Body morph by resetting the Head first.
Note: This only works when you have applied morphs using sliders. It will not work if the character has been imported using the Transformer and the morphs are baked.
bennydee
bennydee
Veteran Member (730 reputation)Veteran Member (730 reputation)Veteran Member (730 reputation)Veteran Member (730 reputation)Veteran Member (730 reputation)Veteran Member (730 reputation)Veteran Member (730 reputation)Veteran Member (730 reputation)Veteran Member (730 reputation)
Last Active: 12 days ago
Posts: 79, Visits: 3.4K
Iclone really need to step up there realtime render quality to the likes of unity 2018 , unreal engine and blender evee even lumion has very realistic render now.
hj
hj
hi Peter
Sorry, that does not work.
If i "Reset" the Body the Head will also resset in the same time.
Also if i  reset the Head, the hole Body wil be reset in the same time.
I find no chance to save the Head-slider without touching the Body
Hans Jörgen
Niki Giovanni
theschemer
theschemer
Distinguished Member (7.6K reputation)Distinguished Member (7.6K reputation)Distinguished Member (7.6K reputation)Distinguished Member (7.6K reputation)Distinguished Member (7.6K reputation)Distinguished Member (7.6K reputation)Distinguished Member (7.6K reputation)Distinguished Member (7.6K reputation)Distinguished Member (7.6K reputation)
Posts: 1.4K, Visits: 2.9K
I don't know if this will help or not but I think it might.
https://forum.reallusion.com/345106/Can-you-save-just-the-head-on-a-CC-character-that-you-made#bm345124
hj
hj
I know this way,
but i can not save a CC3 Avatar in iClone 7.3
https://forum.reallusion.com/uploads/images/56bd2749-9cb2-4d8f-a09d-1195.jpg
Bad issu
Hans Jörgen
Niki Giovanni
theschemer
theschemer
You are right. Major issue. I can export the whole avatar but cannot select just the head. Is there a feedback tracker assigned yet?
hj (11/19/2018)
Hans Jörgen
Hi HJ
You can reset the body without affecting the head and vice versa.
Just select the Body as shown in the screenshot below and then click Reset. This will only reset the body and not the head.
https://forum.reallusion.com/uploads/images/9e4a1cde-7d2b-4371-8053-4121.png
hj (11/19/2018)
I know this way,
Bad issu
Hans Jörgen
I have no problem saving CC3 characters in iClone 7.3 so this isn't a general bug in iClone. Can you save other characters to your custom library?
You might want to try uninstalling and then perform a clean install of iClone 7.3. It certainly isn't normal not to be able to save CC3 characters.
hj
hj
Hi Peter
I reinstall iClone 7.3
the same issues, very bad.
Hans Jörgen
Niki Giovanni
3
