Cannot import a DAZ figure into CC3 (non compatible profile error; but I have no hidden mesh)
Posted By lollosone 7 Years Ago
Cannot import a DAZ figure into CC3 (non compatible profile error; but...
lollosone
lollosone
Posts: 95, Visits: 340
Trying to load a DAZ mesh in CC3; but so far I only get the error because there is no compatible profile.
I did use a G8 variant (Sakura character called Hinami) , LP anime hair for G8 female and sci-fi action clothes set.
After watching the online videos, I did check that no geometry was hidden; in DAZ before exporting; followed to the letter the instructions in the video; and yet, I can't get the figure to load at all in CC3. I also reduced the character resolution to base; but I still get the error.
Not sure at this point what else I should try; I can try other figures; but the expectation was that every G8 DAZ figure should work; so I am afraid to waste more time trying to load more figures and getting the same error.
Threaded View
Threaded View
Forum Post Cannot import a DAZ figure into CC3 (non compatible profile error; but... By lollosone ( 7 Years Ago )
Forum Post Might be hidden mesh or something with that particular character. All... By Rampa ( 7 Years Ago )
Forum Post As Rampa says. If you are still having troubles, let me know... By Kelleytoons ( 7 Years Ago )
Forum Post Hi, I can exclude hidden meshes; since I did check that the mesh is... By lollosone ( 7 Years Ago )
Forum Post As I said, you always need to start first with the basics to make sure... By Kelleytoons ( 7 Years Ago )
Forum Post [quote][b]Kelleytoons (11/7/2018)[/b][hr]As I said, you always need to... By lollosone ( 7 Years Ago )
Forum Post [quote][b]lollosone (11/8/2018)[/b][hr] Which seems to point at the... By Kelleytoons ( 7 Years Ago )
Forum Post [quote][b]Kelleytoons (11/8/2018)[/b] It's the eyeballs -- they are... By lollosone ( 7 Years Ago )
Forum Post I only use CC3 content in iClone, so I can't really help with other... By Kelleytoons ( 7 Years Ago )
Forum Post Make sure your resolution level is normal. No sub-d anything in DAZ. By Rampa ( 7 Years Ago )
Forum Post Someone else just posted the reason, I think. "Custom eyebrows"! Some... By Rampa ( 7 Years Ago )
Forum Post [quote][b]Rampa (11/8/2018)[/b][hr]Someone else just posted the... By lollosone ( 7 Years Ago )
Forum Post Standard G1-8, Hivewire Dawn, Dusk, Gorilla, Luna, DAZ Vic/Mic4, and... By Rampa ( 7 Years Ago )
Forum Post Would be awesome if someone would make an extensive list of what works... By lollosone ( 7 Years Ago )
Forum Post I have two machines. 1 and 2. On machine 1 I can export V4 from... By manjuriaonline ( 5 Years Ago )
Forum Post Reinstall from the hub CC3 (delete program first) on the machine that... By Kelleytoons ( 5 Years Ago )
Forum Post [quote][b]manjuriaonline (11/30/2020)[/b][hr]I have two machines. 1... By Peter (RL) ( 5 Years Ago )
Forum Post Character Creator 3 Does not import anything from Daz. Even the most... By dennisallums ( 7 Years Ago )
Forum Post Okay, relax. Don't give up -- it will work. We just need to find... By Kelleytoons ( 7 Years Ago )
Forum Post i had exactly the same issue with sakura i did every cloth, hair,... By ahingel ( 7 Years Ago )
Forum Post [quote][b]ahingel (12/3/2018)[/b][hr]i had exactly the same issue with... By lollosone ( 7 Years Ago )
Forum Post I had similar eye issues with V4, M4 imports, I had to "LOCK" the eyes... By Snarp Farkle ( 7 Years Ago )
Forum Post Same problem. Clean reinstall. Version is up to date. I am also... By AngeIV ( 4 Years Ago )
Forum Post [quote][b]AngeIV (1/18/2021)[/b][hr]Same problem. Clean reinstall.... By Peter (RL) ( 4 Years Ago )
