Posts: 5.3K,
Visits: 16.8K
Yeah I know.. and I have not switched gears to CC3 either, still thinking in terms of CC2 :) And what interesting, the expression keys are properly mapped and can be further tweaked in Blender
magiccak
magiccak
Visits: 132
Man, thanks a lot... Huge smile drew on my face while I was reading that you figured it out... Could you just please send some screen-shots or more detaily describe how did you do it? Again, I'm new to this, very confused and already spent several hours trying to figure this out - unsuccessfully, don't want to waste more time when someone more skilled can help me :D Again, Thanks!
magiccak
magiccak
Visits: 132
And, additional question, how did you gave that character texture so fast? I always thought it was pretty complicated process and never found a way how to do that easily. Can you advice me in this too please?
Posts: 5.3K,
Visits: 16.8K
You mean texture mapping in Blender? CC does export all textures. I just switched to materials view in Blender. You can see it in video below:
magiccak
magiccak
Visits: 132
Thanks a lot. It's really admirable that you even made a video, I think it will help other new creators too, for sure. Have a nice evening!
Lord of the Stack
Lord of the Stack
Last Active: 8 Years Ago
Visits: 13
Thanks for sharing, just saw the video and followed it, unfortunately for me, it still isn't working for facial expression ;/ Though my facial expressions came from the facial expressions pack (prebuilt ones) they don't appear in the expressions menu, just as prebuilt features to apply, perhaps they're totally separate again. I've only just bought CC3 and it continues to disappoint me TBH, as things like this just fail to work without explanation and the support team are literally useless with their handling of support tickets.
Posts: 5.3K,
Visits: 16.8K
@ Lord of the Stack How did you apply those expressions you mentioned in CC? It really should not matter which facial expression is applied to character. Once saves as Motion Plus, your character would retain the expression in Blender, when that saved Motion Plus is applied at the FBX export screen in CC as shown in video.
Alan_M
Alan_M
Last Active: 6 Years Ago
Visits: 2.9K
magiccak (10/13/2018) Man, I have bought this software for $130, and you are telling me that it's not possible to export the character with facial expression? There is no way I can just freakin' export the face too? CC3 is not an animation system, it is a character creation system. Though you can load up a list of body animation in the FBX export dialog and they will show up in Blender. I transfer animated characters with face to Blender all the time but you need to send your character to IClone first. Apply all you face and body animation there and then export the FBX directly from iClone and not from CC3. I have loaded full characters, with textures, facial animation and body animation into Blender and they work fine with very little tweaking. I can also swap out the FBX motions for those characters in a non-destructive fashion too. I will be putting up an Alembic pipeline to my YouTube channel this weekend and should have the FBX pipeline screedcast recorded by the end of the weekend to show that route. So stay tuned. I am currently using Blender 2.79b and have yet to try 2.8, just waiting on the beta.
Alan M
Posts: 5.3K,
Visits: 16.8K
OP does not have an iClone, only CC3.
Alan_M
Alan_M
Visits: 2.9K
4u2ges (11/16/2018) OP does not have an iClone, only CC3.
Ah!! OK. Well going out of CC3 to Blender certainly works. I just loaded my own Avatar which I exported as LOD0 and imported it into Blender using the FBX default settings in the dialog, did not touch anything. It loaded fine, all the textures turned up and all the Shape Keys are present in the Data tab under the Outliner in Blender and seem to work fine. You can of course add body animation clips into the export dialog, but I have not tried loading any clips that include facial animation, so I am not sure if it is only body animation that comes through or if you can get the face working too. Using the Action Editor in Blender seems to work fine when you have an FBX file that has all your chosen takes in it so it seems to all work for me I have to say.
Alan M
