Strange Normals on Export
Posted By mattrified 8 Years Ago
mattrified
mattrified
Veteran Member (822 reputation)Veteran Member (822 reputation)Veteran Member (822 reputation)Veteran Member (822 reputation)Veteran Member (822 reputation)Veteran Member (822 reputation)Veteran Member (822 reputation)Veteran Member (822 reputation)Veteran Member (822 reputation)
Posts: 11, Visits: 62
So I was doing some experimenting and exported the default avatar with the following export settings:
60% of original size (was 846x459) - Click to enlarge
However, when I imported the character into 3ds max, I noticed the normals on some areas of the character's body were seemingly flipped.
60% of original size (was 846x459) - Click to enlargehttps://forum.reallusion.com/uploads/images/3db4bb94-6aab-46ae-80c2-9a9a.png
Note the square patch in the lower-right window.  This also showed up when I imported into Unity3d.  It was fixed if I chose to calculate normals instead of import.
Additionally, this was fixed when I used the merge UV export functionality.  Anyone else run into this issue?
Posts: 23.1K, Visits: 36.6K
Thanks for the feedback. This has been passed to the CC3 team to investigate.
UPDATE: Please can you refer to the forum post below. We believe this may be related to this issue in 3DS Max.
https://forums.autodesk.com/t5/3ds-max-forum/odd-issue-with-normal-maps/td-p/6742022
Metronomus
Metronomus
Junior Member (182 reputation)Junior Member (182 reputation)Junior Member (182 reputation)Junior Member (182 reputation)Junior Member (182 reputation)Junior Member (182 reputation)Junior Member (182 reputation)Junior Member (182 reputation)Junior Member (182 reputation)
Posts: 13, Visits: 127
Hi! No it isnt just a 3d max problem. I noticed exactly this when i exported the default woman to ue4. Some polys are messed up, for example on the legs. Thought is was a smoothing group issue...
Please fix this. Best regards,
michael
Metronomus (12/2/2018)
michael
Can you post a screenshot showing the issue in UE4. Thanks.
