Wulter
Wulter
Visits: 108
Hi! I've just installed the Iray Render Plugin. Rendering took a while, so I looked at my task manager and noticed, that the Iray Background Renderer used the CPU nearly 100%, while the GPU (GeForce GTX 1070) was used 0%, somtimes 1 o or 2 %. But in the hardware settings the GPU is enabled. Is this normal? Thanks for your advices!
No, not normal.
I know this sounds lame, but try a reboot.
I've seen "something" get all gummed up after a lot of Iray usage, and it falls back to using the CPU rather than GPU. I think it's related to some sort of memory leak, either in Iray or the plug-in. (The plug-in is my prime suspect.) Anyhoo... a reboot seems to restore proper GPU rendering for me.
Good luck, let me/us know if that helped or not.
Last Active: 14 hours ago
Posts: 5.3K,
Visits: 16.5K
I would advice to get a hold of GPU-z Task manager does not take into the the account the computing factor for some reason (at least in my edition of windows) I have to get into it deep and enable computing counter, then it would show me the statistics
sonic7
sonic7
Posts: 1.7K,
Visits: 19.4K
Just by way of reference, I have the GTX-1070 and during iRay rendering, both my CPU and GPU go to Maximum ......
Please be patient with me ..... I don't always 'get it' the first time 'round - not even the 2nd time! :( - yikes! ... ● MSI GT72VR Laptop, i7 7700HQ 4-Core 3.8 GHz 16GB RAM; Nvidia 1070, 8GB Vram ● iClone-7.93 ● 3DXChange Pipeline 7.81 ● CC-3 Pipeline 3.44 ● Live Face ● HeadShot ● Brekel Pro-Body ● Popcorn FX ● iRAY ● Kinect V2 ● DaVinci Resolve17 ● Mixcraft 8.1
Wulter
Wulter
Visits: 108
Thank you very much for your answers! After rebooting the taskmanager showed the GPU usage of character creator correctly. And I installed GPU-Z and it showed that the GPU was working 100% while rendering with Iray background renderer (while the taskmanager still showed 0%). Thanks again
(I disabled the CPU usage in the settings of Iray, it doesn't make any difference. Rendering the standard-image (when opening character creator 3) in HD takes about 1 minute, no matter if CPU is enabled or not. Using only the CPU (without GPU) takes about 8 minutes)
