pupkin96vasya
pupkin96vasya
Last Active: 6 Years Ago
Visits: 72
Привет всем почему у моего персонажа нет белков глаз?
Hi everyone why does my character not have the whites of his eyes?
TARASQUE313
TARASQUE313
Visits: 112
Are they ever gonna get the Apperance editor to work for cc3 or we just gonna have to keep converting cc1 characters over to cc3?
Posts: 23.1K,
Visits: 36.6K
info_186540 (12/1/2019) Hi, I am having a issue with InstaLOD. Whenever I want to re-mesh a object/accessory or export a baked FBX and choose InstaLOD I have a error which states that it can't be completed because of Non-alphanumeric characters in the temp folder. I have made sure there are no non-alphanumeric characters in the temp folder, I have changed the temp folder location from the default, I have even changed the drive and I am still having this issue. Another post stated to delete everything in the windows temp folder which I also tried, but still no luck. At the moment, I am unable to move forward with my project as I can't bake the FBX, or re-mesh it to a workable size. Can someone please assist me on how this error can be fixed?Please can you contact Technical Support if you are still having this problem. To help them, please supply as much information about the steps you take leading up to the problem occurring and also try to include full screenshots of the error messages. This will help them determine if there is an issue with Character Creator or if it is a local system issue.
info_186540
info_186540
Visits: 10
Miranda (RL)
Miranda (RL)
Posts: 1.8K,
Visits: 11.2K
Here is the known issue list in version 3.1. - [Convert CC1 to CC3] All CC1 base characters come with a default displacement texture when converted to CC3. This map can be deleted without any adverse effects.
- [Transformer] iClone G6 character eyeballs offsets slightly when rotated in the Edit Facial panel.
- [Cloth Hide Mesh] Show/Hide group areas intersect while adjusting the cloth hide body mesh settings on the character.
- [Cloth Hide Mesh] Character animation experiences deformations when exported with clothing that carry Cloth Hide Body Mesh data, have the materials merged, and with Delete Hidden Faces disabled.
- [Export] 3ds Max's support for LOD Group is limited with only one layer of the mesh able to be displayed and not editable. Since the problem is not severe, we recommend using Maya instead for the time being and this issue will be re-visited for a future version update.
- [Export] InstaLOD Merge Material function is incompatible and not permitted with FBX export option Mouth Open as Morph enabled.
- [Game Pipeline] Unity Auto Setup does not refresh materials upon completion. One must click on the individual material balls in order to refresh the visuals.
- [Game Pipeline] Unreal currently does not support 16-bit files, so it is best to convert to 8-bit before proceeding to use Unreal.
Posts: 23.1K,
Visits: 36.6K
animagic (6/25/2019)
Peter (RL) (6/24/2019)
edorseey03 (6/23/2019) Neither way is working for me referring to the appearance editor changing skin tone and i have version 3.04. Cant open the editor with cc1 or cc3 character You can only use the Appearance Editor with one of the two specific CC1 Base Characters shown below. Make sure you are loading one of these two and the Appearance Editor will become active. Reluctant to contradict Peter :P, but you should be able use the Appearance Editor with any CC1 character (I just checked with a custom CC1 character). I was referring to the embedded characters that come with CC3. You can, of course, load any custom CC1 character you may have but of the embedded characters included with CC3, you need one of the two I mentioned. The confusion comes because there are other CC1 characters in CC3 but these have already been converted to the CC3 base (see below).
Posts: 15.8K,
Visits: 31.4K
Posts: 23.1K,
Visits: 36.6K
edorseey03
edorseey03
Visits: 75
gordryd
gordryd
Last Active: 4 Months Ago
Visits: 8.1K
It appears from one of your screenshots that your temp folder is "\Desktop\cct3-mpfiles". Hyphen is not an alpha-numeric character. Try changing it to "cct3mpfiles".
