unit23
unit23
Visits: 379
quote]Postfrosch (11/6/2018)
You can adjust the teeth with the slider for teeth[/quote] Thanks for pointing this out. It is confusing when you load the model and it comes with misplaced stuff.
QUBE8
Last Active: 5 days ago
Visits: 53
Hi can you please advice how to fix this in order to make the InstaLOD to work . Some actual steps i have to do in windows 8.1 SP1. ***The application directory must be in alphanumeric characters (not for double byte language system) in order to execute InstaLOD.
Thank you
zyadmardini
zyadmardini
Visits: 24
have you found a solution to this ? having the same problem
Posts: 5.5K,
Visits: 25.7K
QUBE8 (3/5/2019)
Thank you What is the issue that you need a solution to? Your post contains no information whatsoever regarding a problem that you seem to be having. Can you post screen shots of any, and all, error messages that you are getting?
System: Win 10 Pro (21H2), Asus X99-E WS, CPU i7-5930K -3,5 GHz, 32 GB DDR4 2666-16 RAM, NVidia GTX 1080 Ti GPU - 11 GB VRAM(Driver Studio-512.96), Samsung 850 Pro 512 GB SSD, 6 TB HD storage.
QUBE8
Visits: 53
Hello Gerry When it comes to use the InstaLOD this error comes out and i try remove/add underscores/change folder.
Posts: 5.5K,
Visits: 25.7K
When you select Export in the InstaLOD panel  Where are you saving your files? Please post a screen shot similar to this one:
QUBE8
Visits: 53
Ok Gerry here is my settings. I try also change postfixes prefixes, presets nothing helps there is something with that alphanumeric folder guy that i don't understand. Thank you. 1  2  3  4
zyadmardini
zyadmardini
Visits: 24
did you find a solution ???
Sql4088
Sql4088
Visits: 42
*****RESOLVED****** Solution: This issue appears to be caused by using an invalid version of UNITY. Currently, the supported version is 2018.2.14. It's hard to find this requirement, it is listed on this page (scroll to the section " Let’s go into Unity now, and make sure that we are using version "
I was testing an export using InstaLod to Unity. There are issues with - LOD 2+. See screen shots, settings and project attached. I was using a game optimized version of the mesh. CC3 - Trial Version 0 3.04.1422.1 Unity 2018.3.10f1 - LWRP project LWRP Script
3 Years Ago by
Sql4088
Last Active: 5 hours ago
Posts: 20.4K,
Visits: 31.9K
QUBE8 (3/5/2019)
Ok Gerry here is my settings. I try also change postfixes prefixes, presets nothing helps there is something with that alphanumeric folder guy that i don't understand. Thank you. 1   I'm not sure why you have the Desktop set for your temp folder. I would change that. Then make sure the folder names are just one word all made up of letters or numbers. Nothing else.
