[Curve Editor 1.1 NEW RELEASE] Path Position & Offset Editing
Posted By Tony (RL) 7 Years Ago
gerdich
gerdich
Posts: 45, Visits: 525
Nice features! Thank you!
So quaternions will come with the next update I hope. We need them against gimbal lock.
What about the interactivity with Popcorn fx?
Tony (RL)
Tony (RL)
Posts: 222, Visits: 1.7K
Lock Selected / Unlock Selected / Unlock All Keyframes
Three new features have been added to the right-click context menu for the Curve Editor > Outliner
  • Lock Selection will grey out selected curve(s) making them unselectable inside the graph view.
  • Unlock Selection will remove the lock placed on the selected curve(s).
  • Unlock All can be used to remove the lock from all of the curves inside the Outliner, this can be useful when unlocking disparate curves becomes cumbersome.
*All of these functions support multiple selections.
Tony
Product Marketing Manager
Tony (RL)
Tony (RL)
Select All / Invert Selection
Use Select All to select all of the keys inside the Curve Editor.
Use Invert Selection to reverse the selection inside the Curve Editor.
*Multiple selection is supported.
Tony
Tony (RL)
Tony (RL)
Vertical & Horizontal Constraint (hotkey)
Dragging a keyframe while pressing down Shift constrains the movement to either the vertical or horizontal axis depending on how the key is dragged.
76% of original size (was 665x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/0be9eb0b-98db-4966-bc92-9168.gif
Tony
Tony (RL)
Tony (RL)
Match Playhead
When clicked upon, all of the selected keys will align with the time position of the playhead without changing their values.
76% of original size (was 665x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/e6a79212-a26c-47fa-9ca9-e3ba.gif
Tony
Tony (RL)
Tony (RL)
Offset Key
Moving a keyframe with Offset Key enabled, preserves the animation before and after the keyframe by simply shifting the entire sequence.
76% of original size (was 665x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/23f64579-f20e-4987-893d-240d.gif
Tony
Tony (RL)
Tony (RL)
Separate In / Out Tangent
This long awaited feature allows the separate editing of the In and Out tangents of a keyframe.
76% of original size (was 665x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/aece4ecf-93c6-4b07-89ed-d652.gif
Tony
Tony (RL)
Tony (RL)
Editing Path Offset Rotation and Scale
76% of original size (was 665x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/3947b29f-0f60-4dd5-ae7b-784c.gif
Path
Offset Scale
76% of original size (was 665x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/2273bf85-413d-488c-860d-e20f.gif
Tony
Tony (RL)
Tony (RL)
Editing Path Position
The speed at which the path constrained object travels in its set trajectory can be adjusted via Curve Editor > Outliner > Constraint > Path Position (%).
Animating the Path Position can slow and speed up the progress down the track of the path adding tension and rhythm to the path motion.
76% of original size (was 665x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/3f9be11a-9f7a-4d88-8916-6423.gif
Tony
Tony (RL)
Tony (RL)
Finding Path Data in Curve Editor
Curve Editor can now edit Path Position and Offset and there are two ways to find this data:
  1. Right-click on a path constrained item in the scene and select Curve Editor > Constraint to open the Curve Editor along with the object's path data set.
  2. Go to Edit > Constraint inside the Curve Editor panel.
76% of original size (was 665x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/0c94a66e-d4b4-4b1a-9d15-1c41.gif
Tony
