gerdich
gerdich
Visits: 525
Nice features! Thank you! So quaternions will come with the next update I hope. We need them against gimbal lock.
What about the interactivity with Popcorn fx?
Tony (RL)
Tony (RL)
Last Active: 6 Years Ago
Visits: 1.7K
Lock Selected / Unlock Selected / Unlock All Keyframes
Three new features have been added to the right-click context menu for the Curve Editor > Outliner. - Lock Selection will grey out selected curve(s) making them unselectable inside the graph view.
- Unlock Selection will remove the lock placed on the selected curve(s).
- Unlock All can be used to remove the lock from all of the curves inside the Outliner, this can be useful when unlocking disparate curves becomes cumbersome.
*All of these functions support multiple selections.
Tony (RL)
Tony (RL)
Visits: 1.7K
Select All / Invert Selection
Use Select All to select all of the keys inside the Curve Editor. Use Invert Selection to reverse the selection inside the Curve Editor. *Multiple selection is supported.
Tony (RL)
Tony (RL)
Visits: 1.7K
Vertical & Horizontal Constraint (hotkey)
Dragging a keyframe while pressing down Shift constrains the movement to either the vertical or horizontal axis depending on how the key is dragged.
Tony (RL)
Tony (RL)
Visits: 1.7K
Match Playhead
When clicked upon, all of the selected keys will align with the time position of the playhead without changing their values.
Tony (RL)
Tony (RL)
Visits: 1.7K
Offset Key
Moving a keyframe with Offset Key enabled, preserves the animation before and after the keyframe by simply shifting the entire sequence.
Tony (RL)
Tony (RL)
Visits: 1.7K
Separate In / Out Tangent
This long awaited feature allows the separate editing of the In and Out tangents of a keyframe.
Tony (RL)
Tony (RL)
Visits: 1.7K
Editing Path Offset Rotation and Scale Path Offset Rotation
Path Offset Scale
Tony (RL)
Tony (RL)
Visits: 1.7K
Editing Path Position
The speed at which the path constrained object travels in its set trajectory can be adjusted via Curve Editor > Outliner > Constraint > Path Position (%). Animating the Path Position can slow and speed up the progress down the track of the path adding tension and rhythm to the path motion.
Tony (RL)
Tony (RL)
Visits: 1.7K
Finding Path Data in Curve Editor
Curve Editor can now edit Path Position and Offset and there are two ways to find this data:
- Right-click on a path constrained item in the scene and select Curve Editor > Constraint to open the Curve Editor along with the object's path data set.
- Go to Edit > Constraint inside the Curve Editor panel.
