Visits: 62.6K
You create your motions in iClone and load them into the FBX export panel of CC3.
danielswright2311_182877
Visits: 461
Thank you so much for your help, I will read the information and see what I can do.
Check out my new Bible Forums
Posts: 15.8K,
Visits: 31.4K
We cross-posted. I don't work for RL, so I can't really help in regards your expectations. I have used Character Creator since version 1, when it couldn't export anything. More export functionality has been added over time, but it is primarily a tool to create characters.
Posts: 15.8K,
Visits: 31.4K
danielswright2311_182877 (9/28/2018) I was told diffrent, that you can load animations to export with each model, I was told this on this thread by Peter. So that's a new feature than for CC3...:blush: The question then indeed becomes how? :unsure: EDIT: So I checked the manual and it is part of the section about exporting: http://manual.reallusion.com/Character_Creator_3/ENU/3/Default.htm#Character_Creator_3/3/17_Export/Exporting_FBX_Characters_with_iMotion.htm%3FTocPath%3DExport%7CExporting%2520FBX%2520Characters%2520(New)%7C_____1 This is for Motions. If you want facial expressions as well you need the part about MotionPlus. BTW, I haven't tried this, I'm just quoting the manual.
Visits: 461
Peter (RL) (9/25/2018)
danielswright2311_182877 (9/25/2018) I'm, wondering, If I am finished with a character and I load in animations to the character and export it, will it be animated as a set numbered set of frames or we have to export each animated model per animation. Like it just exports one animation at a time per model? You can add multiple animations to be exported with the character and each motion clip can be of varying lengths (frames).
Visits: 461
Posts: 15.8K,
Visits: 31.4K
tomcleaver (9/28/2018) Are you guys planning on supporting GTX 10 series and RTX 20 series graphics cards for CC3?GTX 10 series is already supported (has been since it came out), and RTX 20 should work too, although it's currently a waste of money. Better off with a 1080 Ti.
Posts: 15.8K,
Visits: 31.4K
danielswright2311_182877 (9/28/2018) Ok, so now my cc3 is working but real slow, so I took a little time to test it, till my new graphics card gets here, and I have a real question.
How do I add animations before export?
There are only poses and no place to add animations.
CC3 does not support animation. You need iClone for that.
Visits: 461
Ok, so now my cc3 is working but real slow, so I took a little time to test it, till my new graphics card gets here, and I have a real question. How do I add animations before export? There are only poses and no place to add animations.
claudius_I
claudius_I
Visits: 1.6K
can i reduce the character polygon number without export?
