new update bug: computer crashes while rendering video
Posted By Famekrafts 7 Years Ago
3
4
5
Famekrafts
Famekrafts
Posts: 332, Visits: 2.0K
Ya now after updating iclone to 7.2.1 whenever I am rendering a video Windows 10 is giving a BSOD with error critical process stopped. When I restart, windows will go into repair mode and unless I go into command prompt using window recovery and fix the boot sector, it will not restart.
I am rendering again to check whether it is iclone or something else but happened twice now with the new update.
CTA5, Iclone 7, 3D Exchange Pro, Character Creator 3, Popcornfx plugin, Zbrush, Blender, Vue 2014, Adobe cc suite, Spriter
Homebuild Workstation (Pretty old now but still working great) Win 10, Intel i7 950, 24 GB RAM DDR3, Gigabyte x58a-ud7 motherboard, AMD R9 390 sapphire 8GB VRAM.
Official Website  Reallusion Store
Famekrafts
Famekrafts
and happened thrice now. I made sure internet was off and other processes were off too.
How do I roll back to the old version till the bug is fixed?
R Ham
R Ham
Posts: 628, Visits: 4.1K
Personally I would take a look at my video drivers.  Especially if it only happens when rendering.
"Less clicks good, more clicks bad."
Famekrafts
Famekrafts
seems like I have the latest AMD GPU drivers installed. This was not a problem before the iclone update and games like LOL and others are working fine.
Famekrafts
Famekrafts
I have uninstalled and reinstalled AMD drivers, even recorded using AMD relive and everything works fine.
This time the complete rendering got over and then iclone crashed. No BSOD just black screen and it corrupts the boot sector somehow.
Can anyone tell me how to re roll to the previous version or reinstall iclone without losing all the custom props, motions and avatars I have added?
planetstardragon
planetstardragon
Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)
Last Active: 4 Months Ago
Posts: 11.5K, Visits: 46.0K
that's usually caused by a buffer underrun -   meaning ...that something is not processing info as fast as iclone is giving out info.
so for instance,  if the drive is asleep and you are trying to render,  the buffers get full...but no place to print ...iclone doesn't stop to wait ...it keeps filling the buffer till crash...   OR if you have a bad drvier somewhere and it's clogging up the data stream ...it will crash...it can be a variety of things .....basically whats happening is iclone is sneezing a burst of data stream, and your computer is pinching it's nose -eyes bulge- ....Crash!
"To define Tao is to defile it" - Lao Tzu
Famekrafts
Famekrafts
Ok just for testing I used custom motion on slacker morph and it rendered without any problems. so something in my scene is causing the crash.
I have already rendered a lot of animation from the same scene, the only difference is I just bought this toon frog from iclone store and animated it. It looks outdated because motion puppet isn't there and edit motion layer doesn't open the normal interface but old bones one.
https://www.reallusion.com/ContentStore/ccdproduct.html?contentid=AIC430CIENU011620120315002
https://www.reallusion.com/contentstore/image/ic/20120315034937986/pm20120315034731912_1.jpg
Could this be causing a crash? If so how do I fix it?
Famekrafts
Famekrafts
planetstardragon (4/25/2018)
If that is the case how do I increase the buffer stream? I still believe it is either the frog or a spotlight I have placed in the scene. I am removing the spotlight and re-rendering again.
Basically, the timing of the iclone update matches the toon frog I bought that is why the whole confusion.
planetstardragon
planetstardragon
it's not a matter of speeding up the data stream,   technically that's regulated by the chipset and cpu on your motherboard ....it's more of a case of finding out where the data stream is being interrupted or not keeping up with iclone's data burst when rendering.
that could be your codec,  or your intel driver set, or your video driver, or 3rd party software that's interrupting the stream - ie - video capture software,  malfunctioning anti virus,  even an overheating or slow video card can do that ........it's hard to say because so many things can interfere....but if you follow a troubleshooting path in that direction -  it may help you identify the cause.
Do things like run a direct x test,  look at your system performance for spikes and drops in data - peek at what software was most active in the task manager when iclone crashed....etc ...stuff like that.
Famekrafts
Famekrafts
It was the dumb spotlight I added to the scene with some high values, which was causing the crash. Also, I changed the default video player from windows player to vlc (for opening the video after export). Now the crash is not happening, wasted many hours on this silly mistake. :)
Thanks, everyone.
3
4
5
