OFFICIAL iClone 7.22 Issues Thread
Posted By Peter (RL) 8 Years Ago
Rated 1 star based on 1 vote.
18
19
20
21
22
23
24
pinguintje
pinguintje
Distinguished Member (7.7K reputation)Distinguished Member (7.7K reputation)Distinguished Member (7.7K reputation)Distinguished Member (7.7K reputation)Distinguished Member (7.7K reputation)Distinguished Member (7.7K reputation)Distinguished Member (7.7K reputation)Distinguished Member (7.7K reputation)Distinguished Member (7.7K reputation)
Posts: 834, Visits: 1.1K
Hi Roberto,
The same problem here.:(:(:(
Maybe this helps.
The Protofactor animals are also in the prop folder with a perform function.
This works ok here.
Maybe a tempory solution for your project.
Best Regards,
Arie
Stintfang
Stintfang
Veteran Member (512 reputation)Veteran Member (512 reputation)Veteran Member (512 reputation)Veteran Member (512 reputation)Veteran Member (512 reputation)Veteran Member (512 reputation)Veteran Member (512 reputation)Veteran Member (512 reputation)Veteran Member (512 reputation)
Last Active: 6 Years Ago
Posts: 15, Visits: 295
Yes, I checked the alpha treshold box. It results in a weird looking hair. Not the fine hair texture is shown but something blocky. I can use the treshold slider to make more or less hair visible. I also checked on the material wether the transparency color selector can change the appearance by changing contrast or brightness etc. not helping.
My guess is that the z-buffer depth is not strong enough. the hair consists of a cap, side1, side2, bangs2, bangs1, backunder, front2, front1, back. The original "Emiliahair" for a Poserfigure was meant to be styled and had these layers. It usually gives my character a spectacular fine realistic look (and it had worked in previous versions of iClone). Unfortunately I haven't seen a simpler hair with the same look.
Posts: 5.3K, Visits: 16.8K
Stintfang (8/19/2018)
What OS and DirectX is on your PC?
RobertoColombo
RobertoColombo
Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)Distinguished Member (10.8K reputation)
Posts: 1.6K, Visits: 3.0K
pinguintje (8/19/2018)
Hi Roberto,
Maybe this helps.
This works ok here.
Best Regards,
Arie
Hi Arie,
thanks.
I will use the prop version, nevertheless I think RL shall guarantee to fix the crash because this is not due to the 3rd party content developer but to RL itself, because the character version worked in previous versions of IC.
I am looking forward for an official response for RL about this issue.
Cheers
  Roberto
My PC:
OS: Windows 10 Pro English 64-bit / CPU: Intel i7-9700 3.6GHz / MB: ASUS ROG Strix Z390  RAM: 32GB DDR4 2.6GHz / HD: 2TB+3TB  /
SSD: 2x512GB Samsung 860 EVO + 1x2TB Samsung
VB: Palit GTX2080 TI GamingPro 11GB / AB: embedded in the MB and VB (audio from the MOTU M4 I/F) / DirectX: 12
RobertoColombo
RobertoColombo
Answer from RL to the problem of Protofactor character:
"Feedback Tracker Admin Aug 20, 2018
Hi, Roberto,
Thank you for your feedback.
This issue have been solved during our internal testing, it will be released in next patch.
Reallusion"
Very good news and very fast response time: thumbs up
My PC:
dogged2003
dogged2003
Posts: 418, Visits: 4.5K
Who can explain why the keys A S D F J are guided by global coordinates?
Time is running out.
It is necessary to tell programmers about the existence of local coordinates, and that they can determine the direction of the face!
My YouTube channel.
Posts: 9.2K, Visits: 22.1K
Actually, they are only "guided" by whatever you happen to have selected at the time (IOW, if you select local coordinates for both rotate and move, and then use the shortcut keys, they will switch back and forth and still use local coordinates).
Perhaps your more proper question might be "Is there a shortcut key to change from local to global coordinates"?  The answer to that is no.
CosmoPaul
CosmoPaul
New Member (5 reputation)New Member (5 reputation)New Member (5 reputation)New Member (5 reputation)New Member (5 reputation)New Member (5 reputation)New Member (5 reputation)New Member (5 reputation)New Member (5 reputation)
Last Active: 8 Years Ago
Posts: 3, Visits: 18
iClone 7.22,
I imported two iAvatars to pose them together for rendering purposes, but not animate them.
After posing, I saved the project, but when I try to open that saved project, I get a progress window which gets to "Converting Data.. 19%" and then iClone closes with no error messages.
This happens if I double click the saved project icon, or if I open it through 'recent projects', or if I just use 'open'.
How can I resolve this please?
Windows 10
Intel I7-4710MQ CPU @ 2.5 GHz
32GB RAM
NVIDIA GeForce GTX 880M
Posts: 23.1K, Visits: 36.6K
WaferShaf (8/21/2018)
iClone 7.22,
Windows 10
32GB RAM
Are you able to load other projects successfully such as the sample projects that come with iClone?
If the problem is with just this one project, then it may be that the project file is corrupt in some way. If you have a backup (always advised), try to load that version.
Do also try closing iClone, shutting your computer down completely, and then try to load the project again after a reboot.
CosmoPaul
CosmoPaul
Peter (RL) (8/22/2018)
iClone 7.22,
Windows 10
32GB RAM
Thanks for your response Peter,
I am able to load sample projects , but still unable to open my saved file after reboot. I appreciate that the file may be corrupt, but this is the second time I am having this issue with separate projects. I am wondering if iClone doesn't like me having two iavatars in the same scene, or should it be able to handle that without issue?
Thanks
18
19
20
21
22
23
24
