[PopcornFX 1.01 NEW RELEASE] - Bug Fixes and Updates
Posted By Grace (RL) 8 Years Ago
Grace (RL)
Grace (RL)
Posts: 497, Visits: 5.1K
PopcornFX Plug-in for iClone v1.01 (1.01.1519.1) released on April 11th, 2018
PopcornFX Plug-in Enhancements
1. (*.pkfx) can be dragged and dropped via the viewport.  There is no need to use Plugins > PopcornFX > Import PKFX.
2. The universal Adjust Color panel is now usable with PopcornFX texture channels.
https://forum.reallusion.com/uploads/images/e1f46618-96a3-4111-b71f-9fda.jpg
3. Loading (*.pkfx) files for Lit Particle Material types will generate PBR metallic and roughness textures which can then be modified with Adjust Color tools.
Case in point:
https://forum.reallusion.com/uploads/images/b4863a5b-46cb-44fc-be61-b20b.png
iClone 7.2 vs 7.21
https://forum.reallusion.com/uploads/images/857d70a6-9885-497c-8839-fa17.jpg
PopcornFX Super Tools Bug Fixes
To have these enhanced features take effect, you'll need to load the new Super Tools and then apply your attributes and settings again.
  • Texture & Distortion Emitter
    • The orientation of the Gizmo was not taken into consideration when the align mode was set to Horizontal.
[Before]        [After]
  • Mesh Emitter
    • The resulting rotation was incorrect when Forward to Velocity was disabled.
    • The emitted mesh was erroneously rotated when Spin Speed along Velocity was set to 0.
    • Scale Y and Scale Z attributes were mistakenly swapped.
    • The behavior of Initial Rotate (X/Y/Z) and Free Rotation Speed (X/Y/Z) was improved by mimicking those of the conventional 3D tools.
  • Ribbon Emitter
    • There was incorrect behavior with the Radius Increment Fade Out attribute.
    • There was no effect from the green channel of Texture for Emission, which is used to determine the size of the Ribbon.
    • Velocity (X/Y/Z) gave incorrect results.
    • There was no effect from the Size Randomness attribute.
[Before]        [After]
    • Distortion Intensity for Ribbon was ineffectual and therefore removed from the new Ribbon Emitter tool.
    • Added Z-axis to the Ribbon Twist Direction attribute.
Threaded View
Threaded View
Forum Post [PopcornFX 1.01 NEW RELEASE] - Bug Fixes and Updates By Grace (RL) ( 8 Years Ago )
Forum Post How do we get the newest Popcorn patch? (Installing the iClone patch... By Kelleytoons ( 8 Years Ago )
Forum Post [quote][b]Kelleytoons (4/12/2018)[/b][hr]How do we get the newest... By TonyDPrime ( 8 Years Ago )
Forum Post Yeah, I don't have that installed. Any other way? Edit: Wait, I... By Kelleytoons ( 8 Years Ago )
Forum Post I am finding the following, anyone else? 1) I tried updating, and... By TonyDPrime ( 8 Years Ago )
Forum Post Where do I get the live updater application? I can not fine it... By preacher ( 8 Years Ago )
Forum Post Try this -- with any of the products open and running, go to your... By Kelleytoons ( 8 Years Ago )
Forum Post [quote][b]preacher (4/14/2018)[/b][hr]Where do I get the live updater... By wires ( 8 Years Ago )
Forum Post Hi I have a question: I have updated IC 7 (see picture) That's... By Postfrosch ( 8 Years Ago )
Forum Post [quote][b]Postfrosch (4/13/2018)[/b][hr] Hi I have a question: I... By Grace (RL) ( 8 Years Ago )
Forum Post Hi Grace thanks for your answer Greets from Germany Postfrosch By Postfrosch ( 8 Years Ago )
Forum Post Quick tip if you recently changed your reallusion acct password. Open... By SpiderTec ( 8 Years Ago )
Forum Post Hello, Quick update~ When launch iClone, the Live update or RL hub... By Joanne (RL) ( 8 Years Ago )
Forum Post Thanks Grace, for the updates! By JasonJ68 ( 8 Years Ago )
Forum Post I bought the Popcorn FX plug-in when it first came out, or actually... By Cary B ( 8 Years Ago )
Forum Post Hello all !! Does anyone know where I can find an active link for the... By LookingGlassGraphics ( 8 Years Ago )
Forum Post It seems the whole popcornfx website is down...:unsure: EDIT: The... By animagic ( 8 Years Ago )
Forum Post Thank you. The link is working. I also seen some post stating that the... By LookingGlassGraphics ( 8 Years Ago )
Forum Post Hi, guys, I'll try asking here animagic posted the link to the latest... By Warped Reality VFX ( 8 Years Ago )
Forum Post [quote][b]Kevin L (9/7/2018)[/b][hr]...the latest version is... By jlittle ( 8 Years Ago )
Forum Post The wiki has also links to earlier versions: This is for 1.12:... By animagic ( 8 Years Ago )
Forum Post Thank you guys I have a lot of effects I've been working on for the... By Warped Reality VFX ( 8 Years Ago )
Forum Post Any update as to when this plug-in will be updated to support iray? By joel.lovell ( 7 Years Ago )
Forum Post I find it very annoying to keep buying stuff that gets orphaned when... By joel.lovell ( 7 Years Ago )
Forum Post I too came here to find out compatibility with IRay. From first... By Ascensi ( 7 Years Ago )
Forum Post Hi , Can I export the popcorn fx I make in Iclone to UE4 ? By blade.stoned ( 5 Years Ago )
Forum Post [quote][b]blade.stoned (7/26/2021)[/b][hr]Hi , Can I export the... By toystorylab ( 5 Years Ago )
Forum Post I just bought popcornfx, however it is not showing up under plugin... By cutoffsquid98 ( 5 Years Ago )
Forum Post Hi Eric, you might want to contact Reallusion support to get a quicker... By Ascensi ( 5 Years Ago )
Forum Post [quote][b]Ascensi (8/8/2021)[/b][hr]Hi Eric, you might want to contact... By Zeronimo ( 5 Years Ago )
Forum Post [quote][b]Zeronimo (8/11/2021)[/b][hr][quote][b]Ascensi... By animagic ( 5 Years Ago )
Forum Post [quote][b]Zeronimo (8/11/2021)[/b][hr][quote][b]Ascensi... By Kelleytoons ( 5 Years Ago )
Forum Post [quote][b]erictaredenedo (8/8/2021)[/b][hr]I just bought popcornfx,... By Zeronimo ( 5 Years Ago )
