Posts: 23.1K,
Visits: 36.6K
The characters you need are the ones shown below. Just look for the indicator on the thumbnail where it shows they are CC1. :)
martok2112
martok2112
Posts: 1.6K,
Visits: 2.4K
Hi, Peter. LOL! Funny thing is, I get it sorted out, and then, when I try to do a second project, I'm going "Ok, darn it! Where did I find that CC1 base mesh the first time?!" There are several folders that have CC1 meshes, but unfortunately, many of them are converted to CC3. So, I have to search..and search..and search...until I find just the right mesh. So, when I do find it, I end up having to save a copy of it in Custom just to make it easier to find in the future. :D "It is not so much that I am a smart man, rather that I have simply been accused of having good ideas on occasion." -Martok2112
"Incompetence will always prevail so long as evil men stand by and do nothing." -Martok2112
Posts: 23.1K,
Visits: 36.6K
Hi Martok... Great to hear you got it sorted now. :)
martok2112
martok2112
Posts: 1.6K,
Visits: 2.4K
Ok...I was wondering about that, and just now looked in the CC3 character files. At first, the only ones I saw were CC1 converteds. However, a little further digging did seem to bring up actual CC1 bases that had not been converted. Thank you, Peter. Thank you for your patience and your guidance. :)
martok2112
martok2112
Posts: 1.6K,
Visits: 2.4K
Ok...new hiccup! Apparently, even the CC1 converted characters are still CC3 based. When I try to go into iClone to add a custom RL Head, it still reads an exported CC1 from CC3 as a CC3 avatar. Thankfully, I still have CC1 program.... Let's try that, eh? Ok, it's a bit of ping-ponging, but it looks like it can be done. Oy! (was never good at Ping Pong)
Posts: 23.1K,
Visits: 36.6K
With the introduction of CC3 you now have to export from CT8 as an RLHead as you have found. You can then drag the head onto a CC1 Base Character to apply the head in Character Creator 3. Once the head is applied you can convert the CC1 character to a CC3 character if you wish.
martok2112
martok2112
Posts: 1.6K,
Visits: 2.4K
Same here. Cannot directly export to CC3. Have to do the RL head option, and I'm not sure where to put the RL head in the iC7 Custom files. UPDATE: Ok, I figured it out. When Exporting the RLHead from CT8, store it in Reallusion>Custom>iClone 7 Custom>Face. In iClone 7, Go to the Actor Tab, Custom, and select Head, Your RL head will appear there. However, this will so far only work with CC1 avatars.
bernnelsen
bernnelsen
Last Active: 6 Years Ago
Visits: 118
I have the same issue with CC3 and CT8 pipeline, is there a patch for CC3?
Posts: 23.1K,
Visits: 36.6K
danmiller (9/13/2018)
I'm also having a problem with export. I'm using Crazy Talk 8 Pipeline and Character Creator 2. I have the option to export but it errors out each time. Image attached. Any ideas?  UPDATE: We do have a small patch in the works that should fix this issue. We should have it ready soon. :)
Dan Miller
Dan Miller
Visits: 1.8K
Ok, thanks for the help.
