what do you mean by "sprite list".
Basically you have to create your own sprites.
If you are working in Ai just import the various body parts or separate the body parts in flash. each part is then converted to a movie clip simple and configured to be the "sprite".
If you are using Puppet Producer, the easiest way to make your sprite is:
1. Select the part.
2. Press F8 and convert to movie clip. (the name doesn't matter)
3. Select the part again and click the appropriate part in Puppet Producer.
**PP will apply the correct sprite name to it and place the pivot point on it. You can manually adjust the pivot point to the exact place you need it.
Ibis Fernandez | (available for hire)
Professional Animator, Filmmaker | Creator of the highest quality (modular) G2 rigs for cartoon animator and developer of Toon Titan and Puppet Producer
Author of Flash Animation and Cartooning: A Creative Guide
>>> be sure to check out http://toontitan.com for professional grade assets, templates, and custom tools for Cartoon Animator and more.
