WillFl
WillFl
Last Active: 6 Years Ago
Visits: 161
Hi Guys, not sure if its just me... but I can't seem to click and select anything in the curve editor.. any in-depth curve editor tutorials?
Can(RL)
Can(RL)
Visits: 1.6K
WillFl (12/21/2017) Hi Guys, not sure if its just me... but I can seem to click and select anything in the curve editor.. any in-depth curve editor tutorials?
Hi WillFl, Please check the object needs to "convert to curve data" or not. You can find the "Convert to Curve data" feature via - Select Object > Menu > Plugins > Curve Editor > Convert to Curve data
- Select Object > Right click on the object > Curve Editor > Convert to Curve data
- Select Object > Right click on the Timeline Key or Clip > Curve Editor > Convert to Curve data
Thanks, Can(RL)
WillFl
WillFl
Visits: 161
Can(RL) (12/25/2017)
Hi WillFl, Please check the object needs to "convert to curve data" or not.- Select Object > Menu > Plugins > Curve Editor > Convert to Curve data
Thanks, Can(RL) When I do that, mine looks greyed out... I have tested with different characters and applied mocap to them, but that option still remains greyed out..
Alien Maniac
Alien Maniac
Visits: 2.1K
Confirmed
Sometimes it works but most of the time not. Same issue here. Greyed out. I have had it working only 2 times since purchase. Arrgh. It is greyed out in both menus. NO ability to use the PI. I am uninstalling it and trying to re-install it....hope it works. I will let you know the results here.
MSI GE66 Raider, Intel 10th Gen, I7, SC Turbo to 5.3 GHZ, 240HZ, 64GB 3300 Ram, 2x 1TB M2 SSD Drives, NVIDIA GPU RTX 2070/8GB, 55" Sony 4K Monitor External data drives total 7 TB. and an AUDIO Studio Recording system.
Alien Maniac
Alien Maniac
Visits: 2.1K
I re-installed the Curve editor PI and NO LUCK. It will not work. Same problem. Anyone have a clue? Sure would be nice to be able to use it. I did not put a ticket in yet as there may be a solution here? | | | | | | | | |
Text-to-speech function is limited to 200 characters
WillFl
WillFl
Visits: 161
Space Rider (1/26/2018) Confirmed
I tried re-installing as well, but to no avail. It looks like I can use the arrow keys to go up and down the items in the curve editor but clicking on them is not working.
Alien Maniac
Alien Maniac
Visits: 2.1K
Anyone else having such issues with the curve editor?
WillFl
WillFl
Visits: 161
Space Rider (1/27/2018) Anyone else having such issues with the curve editor?
are there other people using the Curve editor who have encountered the above issue?
Podman1000
Podman1000
Visits: 246
You have to convert the data as your first post reply indcated. It works for me....
Alien Maniac
Alien Maniac
Visits: 2.1K
Um I guess you missed the main post, it is greyed out and " not selectable". | | | | | | | | |
