By WillFl - 9 Years Ago
Hi Guys, not sure if its just me... but I can't seem to click and select anything in the curve editor.. any in-depth curve editor tutorials?
By Can(RL) - 9 Years Ago
WillFl (12/21/2017) Hi Guys, not sure if its just me... but I can seem to click and select anything in the curve editor.. any in-depth curve editor tutorials?
Hi WillFl, Please check the object needs to "convert to curve data" or not. You can find the "Convert to Curve data" feature via - Select Object > Menu > Plugins > Curve Editor > Convert to Curve data
- Select Object > Right click on the object > Curve Editor > Convert to Curve data
- Select Object > Right click on the Timeline Key or Clip > Curve Editor > Convert to Curve data
Thanks, Can(RL)
By WillFl - 8 Years Ago
Can(RL) (12/25/2017)
Hi WillFl, Please check the object needs to "convert to curve data" or not.- Select Object > Menu > Plugins > Curve Editor > Convert to Curve data
Thanks, Can(RL)
When I do that, mine looks greyed out... I have tested with different characters and applied mocap to them, but that option still remains greyed out..
By Alien Maniac - 8 Years Ago
Confirmed
Sometimes it works but most of the time not. Same issue here. Greyed out. I have had it working only 2 times since purchase. Arrgh. It is greyed out in both menus. NO ability to use the PI. I am uninstalling it and trying to re-install it....hope it works. I will let you know the results here.
I re-installed the Curve editor PI and NO LUCK. It will not work. Same problem. Anyone have a clue? Sure would be nice to be able to use it. I did not put a ticket in yet as there may be a solution here?
Text-to-speech function is limited to 200 characters
Space Rider (1/26/2018) Confirmed
I tried re-installing as well, but to no avail. It looks like I can use the arrow keys to go up and down the items in the curve editor but clicking on them is not working.
Anyone else having such issues with the curve editor?
Space Rider (1/27/2018) Anyone else having such issues with the curve editor?
are there other people using the Curve editor who have encountered the above issue?
By Podman1000 - 8 Years Ago
You have to convert the data as your first post reply indcated. It works for me....
Um I guess you missed the main post, it is greyed out and "not selectable".
By Snarp Farkle - 8 Years Ago
Try watching this Webinar, it's very informative.
iClone 7 1 Curve Editor Fun
By elec_pikachu - 6 Years Ago
I had this same problem. The issue is not a bug. It's that you're missing a step. iClone doesn't automatically expand your key-frames inside of a mocap or any other action. You have to force it to expand.
To do this, right click on the motion in the timeline and go to "Sample Motion Clip." You can select to sample optimized or every keyframe. iClone will churn through the motion pulling out the individual keyframes. (May take some time) After that you should see them in the Curve Editor.
Hope this helps.
