IC7.1 - Keys split with move on existed projects
Posted By 4u2ges 9 Years Ago
Posts: 5.3K, Visits: 16.8K
The keys are getting split with move on any of my existing projects. Particularly a copy of the torso key is left behind. For now I just delete them (not sure if it is safe).
But working on existing projects is quite annoying, specially if you try to move multiple keys.
I cannot replicate that on new projects though.
Is anyone else getting the same?
UPDATE: Figured it out! Some tracks were influenced by newly installed Curve Editor!
The fix to the problem if you ever experience it:
Right click on the affected track > Curve Editor > Convert to Curve Data
After this option was applied it turned gray (no longer can be selected).
So if it is available, then the track is affected by "split-key" effect as I call it.
I am yet to start using Curve Editor and figure what "
Convert to Curve Data" option is actually intended for.
Threaded View
Threaded View
Forum Post IC7.1 - Keys split with move on existed projects By 4u2ges ( 9 Years Ago )
Forum Post I can't seem to replicate that issue but I can't seem to CTRL L Mouse... By mark ( 9 Years Ago )
Forum Post Thanks for looking into it Mark. I got some new data. It is actually... By 4u2ges ( 9 Years Ago )
Forum Post When copying and pasting transform keys, I had a problem at least 20... By Jfrog ( 9 Years Ago )
Forum Post I think this is a little different Jfrog. Ok, here is a small project... By 4u2ges ( 9 Years Ago )
Forum Post A hollow key is when there is data on fewer then the XYZ tracks for... By Rampa ( 9 Years Ago )
Forum Post Well, that is the thing Rampa, whether I create a new key (which is... By 4u2ges ( 9 Years Ago )
Forum Post It may very well be just cleanup issue too. It might be drawing an... By Rampa ( 9 Years Ago )
Forum Post I've had "empty" keys left behind, too. The hollow one that indicates... By justaviking ( 9 Years Ago )
Forum Post No they do not do anything - empty. That is what I do - keep deleting... By 4u2ges ( 9 Years Ago )
Forum Post Maybe they go away if you flatten and re-sample your motion layer... By Rampa ( 9 Years Ago )
Forum Post I have not explored that yet. I tried it once.. and went to sleep,... By 4u2ges ( 9 Years Ago )
Forum Post Ok, I flattened and sampled the clip (advice - never do that on a clip... By 4u2ges ( 9 Years Ago )
Forum Post Patient indeed! You do get a clean slate, at least, when you flatten... By Rampa ( 9 Years Ago )
Forum Post No, I cannot really have that. It was just a test. I need to have all... By 4u2ges ( 9 Years Ago )
Forum Post I got the fix!!! Right mouse click on a track > Curve Editor >... By 4u2ges ( 9 Years Ago )
Forum Post [quote][b]4u2ges (11/22/2017)[/b][hr]I am yet to play with Curve... By Me3Dtoo ( 9 Years Ago )
Forum Post WB swooop, yet once again ;) By 4u2ges ( 9 Years Ago )
Forum Post Sigh -- another one to block. By Kelleytoons ( 9 Years Ago )
Forum Post I got some updates. The original fix (Convert to Curve Data) works... By 4u2ges ( 9 Years Ago )
Forum Post I certainly hope it was an honest mistake to report a fixed issue,... By 4u2ges ( 9 Years Ago )
Forum Post It must be a mistake because the issue is marked as "Active" in FT, so... By animagic ( 9 Years Ago )
Forum Post [quote][b]animagic (12/27/2017)[/b][hr]It must be a mistake because... By 4u2ges ( 9 Years Ago )
