Iclone and Orion without post-processing
Posted By diomkal 9 Years Ago
diomkal
diomkal
Posts: 149, Visits: 4.2K
I just  recorded in Orion without touching anything and I transmitted the FBX file in  3DXChange to transform it into IMotion.
Here is the  result I have in Iclone 6 with some camera movements to see some detail.
https://youtu.be/5zpBh5_TpUk
I use the  0.90 trial version of Orion HTC Vive + 3 HTC Tracker + the 2 base station.
It's pretty  promising. If maybe the Iclone team could also look at this side to give us  more possibility, this would be interesting. That is just a suggestion.
And in addition,really the support is reactive and fast.
Last Active: 10 days ago
Posts: 15.8K, Visits: 31.4K
Interesting, looks quite good. Thanks for sharing!
toystorylab
toystorylab
Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)
Posts: 4.6K, Visits: 29.9K
Wow, if this needed no mocap refinement/cleaning this looks really good :w00t:
So you used 3 Vive Trackers and 2 Base Stations, equipment worth approx. 750 $...
Plus an annual subscription of 500 $...
No need for pulling suits, cables...
Seems to be an option for me :D
How big should/can the "walk around"- space be? In square meters? (min-max)
Thanx for showing your results...
paulg625
paulg625
Posts: 388, Visits: 1.4K
Thanks for sharing, looks interesting.
donald.dade
donald.dade
Veteran Member (682 reputation)Veteran Member (682 reputation)Veteran Member (682 reputation)Veteran Member (682 reputation)Veteran Member (682 reputation)Veteran Member (682 reputation)Veteran Member (682 reputation)Veteran Member (682 reputation)Veteran Member (682 reputation)
Posts: 50, Visits: 904
Hi,
OK, I'm even later to this party than I was for Mike Kelly's thread, but I can't get Orion to work.
I got the Orion trial, recorded an FBX to a Genesis avatar, and opened it in 3DXchange 7. It plays fine and seems to work perfectly. But I exported it and it results in no motion whatsoever.
Can you detail the steps you took? I'd appreciate any help you can give.
Thanks,
Donald
"Where there is a bash prompt, there is a way."
