esemgee
esemgee
Visits: 469
I have two items stuck in the content store and I am unable to download them via Install.RLD - I have no other option. I get a nice notice that basically begins: RLDownloaderR2.exe –Bad image and ends: error message 0xc0000020 I know what the problem is – I just can't fix it! Due to lack of space on drive C I have installed Reallusion to drive D. but the content is trying todownload to: C:\ Program Files (x86)\CommonFiles\Reallusion\Downloader\Bin On the D drive I have no 'Program files (x86)' nor, inside Reallusion on D: do I have a 'Downloader' folder. Can this be sorted in some way so I don't have to do a re-install? And if I have to do a reinstall how do I split the paths? The programes and content HAVE to be on D:but I guess the installer has to be on C: and I will have to change the input to file path once prompted. Thanks
videodv
videodv
Visits: 12.0K
I have had this and other problems to fix you need to delete the download folder in the location you have indicated and reinstall the downloader.
Regards Chris
esemgee
esemgee
Visits: 469
Thanks - you mean reinstall to drive C? Or it is possible to get it to work on D? And what am I reinstalling - everything? CC, iC6 and 7?
videodv
videodv
Visits: 12.0K
You just need to install the downloader it will install to the same location as indicated c drive nothing else I'll try to find the link to download from.
Regards Chris
esemgee
esemgee
Visits: 469
thank you so much!! That would be fantastic!
videodv
videodv
Visits: 12.0K
esemgee
esemgee
Visits: 469
Thanks but getting this: This XML file does not appear to have any style information associated with it. The document tree is shown below.<Error> <Code>AccessDenied</Code> <Message>Access Denied</Message> <RequestId>1190ED704FFAE9E2</RequestId> <HostId> d1CUEnZ9LdA1/bI4MyykEFLcd/YR0ciUQZIE0ZhTiS1ENaq57kBdmhmEvLZbkelQiZwknEgqmL4= </HostId> </Error>
videodv
videodv
Visits: 12.0K
esemgee
esemgee
Visits: 469
With your information I was able to track it down and have installed but not run it yet. Again, many thanks!
videodv
videodv
Visits: 12.0K
Your welcome
Regards Chris.
