Downloading new content
https://forum.reallusion.com/Topic342680.aspx
Print Topic | Close Window
By esemgee - 9 Years Ago
I have two items stuck in the content store and I am unable to download them via Install.RLD - I have no other option. I get a nice notice that basically begins:
RLDownloaderR2.exe –Bad image
and ends: error message 0xc0000020
I know what the problem is – I just can't fix it! Due to lack of space on drive C I have installed Reallusion to drive D. but the content is trying todownload to:
C:\ Program Files (x86)\CommonFiles\Reallusion\Downloader\Bin
On the D drive I have no 'Program files (x86)' nor, inside Reallusion on D: do I have a 'Downloader' folder. Can this be sorted in some way so I don't have to do a re-install? And if I have to do a reinstall how do I split the paths? The programes and content HAVE to be on D:but I guess the installer has to be on C: and I will have to change the input to file path once prompted.
Thanks
By videodv - 9 Years Ago
I have had this and other problems to fix you need to delete the download folder in the location you have indicated and reinstall the downloader.
Regards
Chris
Thanks - you mean reinstall to drive C? Or it is possible to get it to work on D? And what am I reinstalling - everything? CC, iC6 and 7?
You just need to install the downloader it will install to the same location as indicated c drive nothing else I'll try to find the link to download from.
Regards
Chris
thank you so much!! That would be fantastic!
Heres the link to download http://file.reallusion.com/Downloader224_Enu.exe
Regards
Chris
Thanks but getting this: This XML file does not appear to have any style information associated with it. The document tree is shown below.
<Error>
<Code>AccessDenied</Code>
<Message>Access Denied</Message>
<RequestId>1190ED704FFAE9E2</RequestId>
<HostId>
d1CUEnZ9LdA1/bI4MyykEFLcd/YR0ciUQZIE0ZhTiS1ENaq57kBdmhmEvLZbkelQiZwknEgqmL4=
</HostId>
</Error>
Sorry this is the link http://file.reallusion.com/Downloader224_Enu.exe
With your information I was able to track it down and have installed but not run it yet. Again, many thanks!
Your welcome
Regards
Chris.
Tried to run, no luck - have re-booted, no luck - will keep you informed but halfway there!
No luck so far - even after a reboot... will let you know!
DONE IT! Thanks!
Good to hear.
