Problem with Material in iClone7.02.915.1
Posted By pinguintje 8 Years Ago
pinguintje
pinguintje
Distinguished Member (7.7K reputation)Distinguished Member (7.7K reputation)Distinguished Member (7.7K reputation)Distinguished Member (7.7K reputation)Distinguished Member (7.7K reputation)Distinguished Member (7.7K reputation)Distinguished Member (7.7K reputation)Distinguished Member (7.7K reputation)Distinguished Member (7.7K reputation)
Posts: 834, Visits: 1.1K
When I drag and drop a material (e.g. CloneCloth for Gwynn, Gwynn upper, overcoat B) I get the message "Failed to load material, this is not a valid material file"
The overcoat is there but I think the colours are wrong.
76% of original size (was 663x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/867568a0-4c93-46c6-8ca5-5f42.jpg
Is anyone else having this problem? (It is since the update to V.7.02)
Best Regards,
Arie
Postfrosch
Postfrosch
Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)Distinguished Member (39.0K reputation)
Posts: 6.9K, Visits: 18.4K
Arie,
i have the same problem
Greets from Germany
Werner
76% of original size (was 663x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/cd9c9a06-21a5-44c5-9f67-6810.jpg
Clark
Clark
Veteran Member (861 reputation)Veteran Member (861 reputation)Veteran Member (861 reputation)Veteran Member (861 reputation)Veteran Member (861 reputation)Veteran Member (861 reputation)Veteran Member (861 reputation)Veteran Member (861 reputation)Veteran Member (861 reputation)
Posts: 71, Visits: 7.9K
I also had the same problem when applying materials to structures.
Posts: 9.2K, Visits: 22.1K
Yeah, this happens to me on any non-PBR material (although everything I do nowadays is PBR so it doesn't worry me at all).
videodv
videodv
Posts: 342, Visits: 12.0K
Yep same here with Si-Fi suites
pinguintje
pinguintje
Thank you all for the comments.
I have posted this in the Feedback Tracker.
Link: Feedback Tracker
I hope RL will fix it.
Best Regards,
Arie
Posts: 15.8K, Visits: 31.3K
One thing to be aware of is that if the project is set to PBR, the Traditional textures look washed out. Setting the project to Traditional fixes the colors for me.
76% of original size (was 663x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/06ee63cc-7153-4d86-aa6a-f129.png
Posts: 5.7K, Visits: 26.5K
I tested this issue using Gwynn and the Gwynn upper, overcoat B. The error warning message about Material loading appears, but the Material is loaded as already posted by Arie and others.
I loaded Gwynn and applied the Material to her Overcoat in my default empty project that is set to PBR:
76% of original size (was 663x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/8b88a508-c3a5-4759-89ac-2a2d.png
The Overcoat is "washed out" using these settings.
Changing the project settings to "Traditional" gives this result:
76% of original size (was 663x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/93f09bc4-2020-43bd-9609-04e8.png
Now, changing the project back to PBR results in this:
76% of original size (was 663x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/3deb0080-9a23-4d73-9d31-5907.png
During all of this I never closed the Project settings window after each Color Management change, and the Materials were always kept as Traditional:
76% of original size (was 663x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/4fb9fdd8-19e2-466a-8735-2141.png
Interesting behaviour on the Material that needs looking into a little more.
Edit:
I've added a comment to the FT issue.
pinguintje
pinguintje
@animagic and wires
Thank you for the help.:):):)
It's ani magic.:laugh:
Maybe RL conjure up a solution.
Best Regards,
Arie
clark.gerald7
clark.gerald7
New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)
Last Active: 8 Years Ago
Posts: 2, Visits: 6
I am getting the same message but the material changes in spite of the error message.  My latest project with 7.02 is crashing continuously with no know reason, even during simulation?
