Problem with Material in iClone7.02.915.1
https://forum.reallusion.com/Topic342528.aspx
Print Topic | Close Window
By pinguintje - 9 Years Ago
When I drag and drop a material (e.g. CloneCloth for Gwynn, Gwynn upper, overcoat B) I get the message "Failed to load material, this is not a valid material file"
The overcoat is there but I think the colours are wrong.
https://forum.reallusion.com/uploads/images/867568a0-4c93-46c6-8ca5-5f42.jpg
Is anyone else having this problem? (It is since the update to V.7.02)
Best Regards,
Arie
By Postfrosch - 9 Years Ago
Arie,
i have the same problem
Greets from Germany
Werner
By Clark - 9 Years Ago
I also had the same problem when applying materials to structures.
By Kelleytoons - 9 Years Ago
Yeah, this happens to me on any non-PBR material (although everything I do nowadays is PBR so it doesn't worry me at all).
By videodv - 9 Years Ago
Yep same here with Si-Fi suites
Thank you all for the comments.
I have posted this in the Feedback Tracker.
Link: Feedback Tracker
I hope RL will fix it.
Best Regards,
Arie
By animagic - 9 Years Ago
One thing to be aware of is that if the project is set to PBR, the Traditional textures look washed out. Setting the project to Traditional fixes the colors for me.
https://forum.reallusion.com/uploads/images/06ee63cc-7153-4d86-aa6a-f129.png
By wires - 9 Years Ago
I tested this issue using Gwynn and the Gwynn upper, overcoat B. The error warning message about Material loading appears, but the Material is loaded as already posted by Arie and others.
I loaded Gwynn and applied the Material to her Overcoat in my default empty project that is set to PBR:
https://forum.reallusion.com/uploads/images/8b88a508-c3a5-4759-89ac-2a2d.png
The Overcoat is "washed out" using these settings.
Changing the project settings to "Traditional" gives this result:
https://forum.reallusion.com/uploads/images/93f09bc4-2020-43bd-9609-04e8.png
Now, changing the project back to PBR results in this:
https://forum.reallusion.com/uploads/images/3deb0080-9a23-4d73-9d31-5907.png
During all of this I never closed the Project settings window after each Color Management change, and the Materials were always kept as Traditional:
https://forum.reallusion.com/uploads/images/4fb9fdd8-19e2-466a-8735-2141.png
Interesting behaviour on the Material that needs looking into a little more.
Edit:
I've added a comment to the FT issue.
@animagic and wires
Thank you for the help.:):):)
It's ani magic.:laugh:
Maybe RL conjure up a solution.
Best Regards,
Arie
By clark.gerald7 - 9 Years Ago
I am getting the same message but the material changes in spite of the error message.  My latest project with 7.02 is crashing continuously with no know reason, even during simulation?
By Peter (RL) - 9 Years Ago
Just to let you know this issue has been fixed in the iClone 7.1 update (due later this week or early next week). :)
Peter (RL) (11/13/2017)
Most unusual to see something about a large update announced in a 2 month old post. :ermm::blink::unsure::Whistling:
By TonyDPrime - 9 Years Ago
Thanks!....Looking forward to this!
wires (11/14/2017)
Hi Gerry,
It wasn't an announcement. It was simply updating a thread with the latest information I had. As for announcements, these are now handled by the marketing team so out of my hands now. ;)
Peter (RL) (11/15/2017)
wires (11/14/2017)
Hi Gerry,
Some things don't change for the better - pity.:ermm:
After the update to V.7.1.1116.1 the message "failed to load material, this is not a valid material file" no longer appears.
That's ok.
But I have to check the box "use RGB"  (see picture) to get the good colour.
Is that the meaning?
https://forum.reallusion.com/uploads/images/1abe668a-ed40-4915-835b-c7b5.jpg
I dont know if it is material related, but after the update I have now a silly cane. (Accessory Old woman cane, Pack: Cranky old women).
Yesterday (before the update) it was ok.
Now I only see this.(The opacity for each material is 100)
https://forum.reallusion.com/uploads/images/e3377d8c-8674-4b69-be93-86b1.jpg
What could be the problem? (in iClone 6 it is ok)
Best Regards,
Arie
