(A solution) Rendering Large Projects 3 Million Poly+ -On Export iClone Crashes
Posted By Ascensi 7 Years Ago
(A solution) Rendering Large Projects 3 Million Poly+ -On Export...
Ascensi
Ascensi
Last Active: 4 days ago
Posts: 247, Visits: 1.8K
I had to share this with everyone because the information wasn't available to me in any tutorial or manual.. I had come to a realization.
iClone has it's own rendering built in and is not needed when exporting -it just sucks up all of your resources displaying the scene and chokes the resources needed to export large projects.
Steps for optimization
1.Set iClone to use the quick shader or less (if there is a less)
2. Set the displacement on your models to 0 and then once imported into Indigo set them to your original values.
3. Make sure your hard drive(s) have a lot of Virtual memory - I set mine up  from 3k to 40k max -for Audio projects/DAW the opposite is true for stability.
4. Having Solid state hard drive speeds things up a bit.. USB HDs require more memory. Creating the Indigo project files on a simple USB HD only allowed saving at 128 MB/s where as the SSD allowed it 256-512 Mb.
5. Most may already know this but disabling any non essential program running in the background can speed things up as well as prevent crashes.
I think it would be good that Reallusion adds a switch in iClone to lower the quality of all features when export is pressed or at least update the manual with performance & stability procedures.. I spent a lot of time wondering what was wrong with the project, iClone or Indigo. I contacted Reallusion's support and was told to keep everything set to max quality for final render -so wrong when using Indigo instead of iClone's render system.. it's Indigo Render where the quality is to be manufactured from, we just need to get our files there!
Store Page Link
AMD 4.5 GHz 16 Cores  | 128 GB | RTX 4090 | Window11 | Houdini FX 18.5 | Zbrush 2023 | Maya 2014 | Adobe CS6 | Sonar Producer X3 | iC8, CC4 | DTS Master Audio Suite | Perception Neuron 32 Alum Edition | Akeytsu
7 Years Ago by Ascensi
SeanMac
SeanMac
Posts: 416, Visits: 3.4K
Thanks for the tip, Ascensi
freerange
freerange
Last Active: 7 Years Ago
Posts: 165, Visits: 437
nice work, you need to have progressive renders though, the interlacing is making things look wonky. Pretty much you never need to render interlaced video anymore.
Free Range
My IMDB
