Curve Editor 07: Curve Presets
Posted By Grace (RL) 9 Years Ago
Grace (RL)
Grace (RL)
Last Active: 5 Months Ago
Posts: 497, Visits: 5.1K
Grace (RL)
Grace (RL)
Intro
  • Curves now have Transition Curve Preset Types which provides an abundant way to re-interpret the motions.
  • The Transition Curve Type is applied from the previous key to the next or current key.https://forum.reallusion.com/uploads/images/bdab6791-8552-48bc-9fd5-4b70.gif
There are two ways to change the Transition Curve:
  • Click on Presets > Transition Curve in the menubar
  • Select Presets > Transition Curve in the context menu
https://forum.reallusion.com/uploads/images/e2dbc6d7-c2fe-47c6-a53e-255c.jpg     https://forum.reallusion.com/uploads/images/7f6a5349-dc4b-43be-ae45-cff9.jpg
Preview
  • Once a Curve Preset is picked, the results will be immediately visible in the viewport, making it fast for the user to pick the most suitable transition type.
  • The Curve Preset preview will apply to the key before and to the present key.
https://forum.reallusion.com/uploads/images/8849dc2d-ee0e-41c9-8fdb-e86f.gif
Move Key
The
Transition Curve is preserved even when the keys are moved about.
https://forum.reallusion.com/uploads/images/55152041-8bfd-4091-b7df-06ac.gif
Add & Delete Key
Adding keys to a preset enabled curve will change the effective range of the presets to factor in the additional keys.
https://forum.reallusion.com/uploads/images/8ce0a344-2b41-4caa-bcef-262d.gif
https://forum.reallusion.com/uploads/images/5e2e12f3-3416-44eb-985e-3740.gif
Revert
Revert can be used to return to the curve to its original Transition type.
https://forum.reallusion.com/uploads/images/836e2bd8-5ae5-4b4a-9f6d-9413.gif
Grace (RL)
Grace (RL)
Types
Accelerate
https://forum.reallusion.com/uploads/images/6a7150cf-6287-4d83-b7ff-eeee.gif
Decelerate
https://forum.reallusion.com/uploads/images/11a83073-c594-44ba-aa78-1503.gif
Smooth In & Smooth Out
https://forum.reallusion.com/uploads/images/c56f6fff-d4e0-41b8-a01e-a258.gif
Pause & Move
https://forum.reallusion.com/uploads/images/e02a570f-4896-46ee-a382-1211.gif
Gain Momentum Then Move
https://forum.reallusion.com/uploads/images/fb56f246-d331-4c40-84be-36bb.gif
Damping
https://forum.reallusion.com/uploads/images/60b216ac-2850-460b-8225-15e1.gif
Gain Momentum & Damp
https://forum.reallusion.com/uploads/images/9a4f3a42-00e5-4afb-993f-3c3e.gif
Stutter In
https://forum.reallusion.com/uploads/images/54067902-556c-4ddf-b3ba-040c.gif
Bounce Out
https://forum.reallusion.com/uploads/images/e7b23310-32a4-44b5-a84b-6e36.gif
Stutter In & Out
https://forum.reallusion.com/uploads/images/1f72411f-028d-4d36-926e-bacc.gif
Elastic In & Sudden Out
https://forum.reallusion.com/uploads/images/a1198949-f20b-48c8-8f0e-133d.gif
Sudden In & Elastic Out
https://forum.reallusion.com/uploads/images/23aec649-dec2-4568-8e21-148b.gif
Elastic In & Out
https://forum.reallusion.com/uploads/images/20ab3f85-73bf-4592-ba1f-55bc.gif
Stepped
https://forum.reallusion.com/uploads/images/c233581c-06b1-4db8-a6e7-2d0a.gif
Linear
https://forum.reallusion.com/uploads/images/bbf786eb-87c8-4893-993e-197a.gif
Grace (RL)
Grace (RL)
Sample & Refine Keys
Sample
  • With a preset enabled curve, one can use the Sample tool to turn the transition curve into individual keys for editing.
  • Use the Sample All function to turn all of the selected components motion curves into discrete keys.
https://forum.reallusion.com/uploads/images/a3c5da93-524c-4bf8-a554-94cf.gif
https://forum.reallusion.com/uploads/images/ef2ae67d-a1fe-41a4-8ac3-9bdc.gif
Refine Keys
  • Refine Keys lets you optimize a range of keys while attempting to preserve the overall curve.
  • Refine Keys is usually applied to densely keyed motion curves to simplify the curve and reduce the number of keys.
  • Refine Keys is not recommended on curves containing very few keys.
https://forum.reallusion.com/uploads/images/d2ec4fcb-69fe-4f4b-b926-82c6.gif
Refine Keys UI & Concept
  • Before applying Refine Keys, you first need to pick a threshold value ranging from 0 to 1.
  • Refine Keys is applied with the technique of curve fitting while the threshold stands for the curve fitting error threshold.  Essentially, threshold affects the accuracy for the resultant curve compared with the original curve.
  • A larger threshold value results in less accurate curve fitting (the motion curve may become smoother but may deviate quite a bit from the original curve, see the figure in the next page).  By contrast, a smaller threshold will create a curve with better fidelity.
  • As a consequence, higher threshold values result in less keys, while lower threshold values result in more keys (see figure in the next page).
  • The "Preview Key Information" checkbox gives you the option to see the amount of keys prior to and after threshold optimization.
https://forum.reallusion.com/uploads/images/81708730-9698-4ae0-b321-b5e9.png
https://forum.reallusion.com/uploads/images/f2cc4c46-cd77-4e7b-a111-da8b.pnghttps://forum.reallusion.com/uploads/images/36aabd8e-e174-4cab-a318-1795.png
PREVIOUS: 06 - FK Mode               NEXT: 08 - Applications
