Curve Editor 05: Outliner Intro
Posted By Grace (RL) 8 Years Ago
Grace (RL)
Grace (RL)
Posts: 497, Visits: 5.1K
Grace (RL)
Grace (RL)
Tree / List View
  • When an Avatar is selected, the default Outliner display mode is List View.
  • When a Prop is selected, the default Outliner display mode is Tree View.
  • You can switch between the display modes at any moment.
https://forum.reallusion.com/uploads/images/65f3f0d8-7ec3-42a6-bac5-1bc0.jpg   https://forum.reallusion.com/uploads/images/d49faa9d-171f-40d9-8ce9-c4be.jpg
Grace (RL)
Grace (RL)
Color Coding
Curve Editor’s color coding is the same as the gizmo’s XYZ axis:
  • Red for X axis
  • Green for axis
  • Blue for axis
https://forum.reallusion.com/uploads/images/716267bd-6f5d-4fbe-a793-730e.jpg
https://forum.reallusion.com/uploads/images/ee88ef35-0cd3-491b-b088-5f8a.jpg
https://forum.reallusion.com/uploads/images/73d6e660-0fb9-4025-a266-d39d.jpg
In addition, different shapes now denote different RTS components:
  • Round circle for rotation
  • Triangle for translation
  • Square for scale
https://forum.reallusion.com/uploads/images/4b953a1d-02ab-4e9b-9d18-7e38.jpg
Grace (RL)
Grace (RL)
Relations between Outliner and the Graph View
When one or more items in the Outliner is selected, the Graph View will update to show the corresponding curve lines.
The animations below demonstrate the adjusted results for the RTS keys.
Position: X
Position: Y
Position: Z
Rotate: X
Rotate: Y
Rotate: Z
Scale: X
Scale: Y
Scale: Z
Grace (RL)
Grace (RL)
Selection Visibility
Specification:
  • Ctrl+dragging on the components of the Outliner will select several components at once.
  • Ctrl+click on a single component to add it to the selection list and do it again to take out out of the selection list.
  • Shift+click to select an entire range of components.
  • Selected components are not restricted to single bones or groups.  Disparate selections can span across the entire list and anything selected will show up in the Graph Editor.
https://forum.reallusion.com/uploads/images/e5d85cc3-27b1-47d4-8875-0974.gif
PREVIOUS: 04 - Tool Bars               NEXT: 06 - FK Mode
