Grace (RL)
Grace (RL)
Visits: 5.1K
Selection Visibility
Specification: - Ctrl+dragging on the components of the Outliner will select several components at once.
- Ctrl+click on a single component to add it to the selection list and do it again to take out out of the selection list.
- Shift+click to select an entire range of components.
- Selected components are not restricted to single bones or groups. Disparate selections can span across the entire list and anything selected will show up in the Graph Editor.
Grace (RL)
Grace (RL)
Visits: 5.1K
Relations between Outliner and the Graph View
Grace (RL)
Grace (RL)
Visits: 5.1K
Color CodingCurve Editor’s color coding is the same as the gizmo’s XYZ axis:
Grace (RL)
Grace (RL)
Visits: 5.1K
Tree / List View- When an Avatar is selected, the default Outliner display mode is List View.
- When a Prop is selected, the default Outliner display mode is Tree View.
- You can switch between the display modes at any moment.
Grace (RL)
Grace (RL)
Visits: 5.1K
Curve Editor 05: Outliner Intro
