What's New in CrazyTalk 8.11
Posted By Peter (RL) 8 Years Ago
duchess110
duchess110
Posts: 2.0K, Visits: 15.5K
Peter (RL) (7/7/2017)
Hi Duchess,
We believe we have found the cause of this issue. Please see the thread below for more information and a temporary solution.
https://forum.reallusion.com/333023/Trouble-Sending-Characters-To-And-From-Character-Creator
HI Peter
Please see my reply
https://forum.reallusion.com/FindPost333032.aspx
Duchess Designs Store
Posts: 23.1K, Visits: 36.6K
Hi Duchess,
duchess110 (7/4/2017)
Hi Peter I did make sure that before installing the full release that all previous EA  Pre Release etc had been removed.
But again I did do an uninstall of 3dxchange7 then cc2 then ic7 shut down pc.
Then did a restart and reinstalled.
1 - iC7
2 - CC2
3 - 3Dxchange
Same problems again as my list above also now I have lost the desktop image on the icons for iC7 and 3Dxchange
I have not put anything yet on the feedback tracker as not sure which of the software if not all is causing me this problem.
EDIT
What I will do now is uninstall again and switch off for the night and try again tomorrow.
Hi Duchess,
I'm sorry to hear you are still having these problems. We are looking into this strange issue. As soon as I have more news I will update again.
duchess110
duchess110
Peter I see someone else also cannot export from CC to iClone so perhaps it is more of a software bug rather than my pc.
https://forum.reallusion.com/332705/Export-to-Iclone-stopped-working
duchess110
duchess110
Peter (RL) (7/4/2017)
I think there is a path issue going on here.
The reason I am thinking this is
1- Crazy Talk 8 Pipeline cannot export Head to CC2
2- In iC7 If I try send character to Edit in CC2 - Failed to Load
3- In CC2 try send Character to iC7 - Failed to Load.
I can see the temp avatars created in my Temp Folder created on my D drive. Named iC7 CC2 Temp
Inside this folder there is a folder for iC7 with the necessary bits in
Also there is a Folder for CC2 again with the necessary bits in but they are just not talking to each other.
Operating System Windows 7 sp1
Hi Duchess,
Did you by any chance install the full version of iClone 7 while still having either of the iClone 7 or 3DXchange 7 Pre-release versions installed?
We are seeing a number of different problems caused when the full versions have been installed while Pre-release versions are still present.
The correct procedure was to uninstall BOTH iClone 7 + 3DXchange 7 Pre-release versions first. Then install iClone 7 followed by 3DXchange 7.
Sadly in this situation you may need to uninstall everything and start again installing iClone 7 first, Character Creator 2.1 and then 3DXchange 7. Doing this should reinstate the link between all the products. Although this may seem a daunting task you shouldn't have to reinstall any content as this will not be removed.
1 - iC7
2 - CC2
3 - 3Dxchange
EDIT
vidi (7/4/2017)
The export RLHead function would not send the RLHead file to Character Creator 2 or above.
No sucess
I get this message when trying to send the head to CCreator2
I get the same Message
Hi Vidi,
Please see my reply to Duchess, the same issue may apply to you also.
Bray42 (7/4/2017)
Nice BUT when can we get the image and video background option?
Adding a custom background image is already available. Just add your image in Create > Atmosphere Settings.
Sadly video backgrounds are not coming to CrazyTalk 8.
@Postfrosch, @lesdodds
You can still export from CrazyTalk 8.11 as an RLHead which can be applied to a Character Creator 1.52 head.
Hi Duchess,
lesdodds
lesdodds
Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)
Posts: 246, Visits: 2.6K
Just updated Crazytalk to 8.11 and now it will not export to cc 1.52.
THANKS:cool::exclamation:
Lester:)
 My YouTube
My Facebook
"All the adversity I've had in my life, all my troubles and obstacles, have strengthened me... You may not realize it when it happens, but a kick in the teeth may be the best thing in the world for you."
-Walt Disney
