Problem with 'ah' viseme in iclone 7
Posted By gogstudios 4 Years Ago
gogstudios
gogstudios
Posts: 51, Visits: 326
Hi. I am facing a weird issue where my character(CC 2.0) opens his mouth more before and after the 'ah' viseme frame. Every other viseme works perfectly. I exported the character to 3dx7 and inspected the expression editor where the viseme section displays open correctly. I do not have any other face key influence in the iclone 7 timeline. Can you please resolve this? This bug existed in iclone 6 as well for more than a year. Come on reallusion, you can't have such low level bugs in your software in it's 7th version.
154th frame:
155th frame:
156th frame
SkyRoads clone for Android: https://play.google.com/store/apps/details?id=com.gog.skyroads
Target Number - A math puzzle game: https://play.google.com/store/apps/details?id=com.tomag.targetNumber
4 Years Ago by gogstudios
Distinguished Member (24.2K reputation)Distinguished Member (24.2K reputation)Distinguished Member (24.2K reputation)Distinguished Member (24.2K reputation)Distinguished Member (24.2K reputation)Distinguished Member (24.2K reputation)Distinguished Member (24.2K reputation)Distinguished Member (24.2K reputation)Distinguished Member (24.2K reputation)
Last Active: 13 hours ago
Posts: 13.1K, Visits: 23.2K
I'm looking at your screen captures and it seems that the expressiveness settings are very low; they should be between 50 and 100% for normal speech.. That will have an effect on how much the viseme affects the mouth shape.
I've just done a test in IC7 and it works for me.
It also worked in IC6, and there is no entry in FT that reports it as defective in IC6. If bugs are not reported, RL will not be able to investigate.
https://forum.reallusion.com/uploads/images/1f3bed13-1788-45e1-9ace-4fd0.jpg
Distinguished Member (70.9K reputation)Distinguished Member (70.9K reputation)Distinguished Member (70.9K reputation)Distinguished Member (70.9K reputation)Distinguished Member (70.9K reputation)Distinguished Member (70.9K reputation)Distinguished Member (70.9K reputation)Distinguished Member (70.9K reputation)Distinguished Member (70.9K reputation)
Posts: 18.5K, Visits: 28.5K
I'm also not seeing this issue but do try what Animagic suggested. If you still have problems please send us a download link to your project using the link below. We will then check it out to see what the problem is. Thanks.
http://www.reallusion.com/CustomerSupport/UserEx/QForm.aspx
charlenemedwards
charlenemedwards
Veteran Member (763 reputation)Veteran Member (763 reputation)Veteran Member (763 reputation)Veteran Member (763 reputation)Veteran Member (763 reputation)Veteran Member (763 reputation)Veteran Member (763 reputation)Veteran Member (763 reputation)Veteran Member (763 reputation)
Posts: 24, Visits: 105
This REALLY IS a disturbing problem. Something iIS wrong. Once you place a voice on the track, the mouth takes on the shape for the first lip key in  the voice clip. The mouth is crazy after the voice finishes. The means Viseme is preparing the mouth early (opening the mouth in many cases depending on the lip key) and making void the face keys I have set because viseme is doing an override. I agree--come reallusion. I purchased ic7 in april prebuy--been waiting patiently without complaint--now I can't animate. If you haven't solved this with a patch by now, please help me with this reallusion.  Thanks
charlenemedwards
charlenemedwards
Addendum to post.  Just to prove this is true, I created a dummy script --silent--with no sound--and placed it right before my real script and also copied it to follow the real script. Voila. The mouth now remains in tact with its proper shape until the script begins.  But who wants to add dummies all over the place? Again, please help---not being arrogant, just need help
charlenemedwards (6/26/2017)
I have run a few tests and I'm not seeing the mouth take the shape of the first key early or the "crazy" mouth after the voice clip finishes. As I mentioned in my previous reply to the OP, please can send a download link to your project using the Support Form below. We will then check it out to see what the problem is. Thanks.
Distinguished Member (17.7K reputation)Distinguished Member (17.7K reputation)Distinguished Member (17.7K reputation)Distinguished Member (17.7K reputation)Distinguished Member (17.7K reputation)Distinguished Member (17.7K reputation)Distinguished Member (17.7K reputation)Distinguished Member (17.7K reputation)Distinguished Member (17.7K reputation)
Posts: 8.1K, Visits: 25.8K
In iClone 6, I usually found the "Ah" viseme to be disproportionately strong relative to the others, and routinely lowered it's strength from 100 to about 60.  Strange that you are reporting the opposite problem here in iC7.
Since a both a moderator and highly respected forum member were unable to duplicate your issue, your best recourse is to follow Peter (RL)'s request of finding a way to get the project to him so he can take a look at it.  We would all love to see you get this resolved.
Good luck.
Desktop (homebuilt) - Windows 7, i7-3770k CPU, GTX 1080 GPU (8GB), 16GB RAM, Asus P8Z77-V Pro motherboard, 1TB SSD, terabytes of disk space, dual  monitors.
4 Years Ago by justaviking
gogstudios
gogstudios
I could replicate it. I have shared the project link below. The problem occurs when 2 consecutive 'ah's of increasing intensity are present. Please fix this ASAP. This can be replicated in iclone 6 as well.
https://drive.google.com/file/d/0B0HZ8z7uYVgZNk5tLUY0blFYR3M/view?usp=sharing
EDIT: I have created a ticket for this.
@gogstudios: I played your project, and the ah's  rendered according to what the visemes indicate, as can be seen in the video:
As this doesn't seem to be a universal issue, your best recourse is support at this point.
What is your system specification?
gogstudios
gogstudios
Hi Animagic. There is very noticeable mouth stutter. Go frame by frame and you'll notice. This mouth stutter looks weird when seen anywhere even though it'll be for a few 2-3 frames only. So your video proves that it's not an issue with just my computer.
