Waterlane Studios
Waterlane Studios
Visits: 309
Hi - My decal tabs have no options for images to be 'input'. Can anyone tell me why this is? This is working fine in CC1.5 but not in CC2 I've just installed the latest version of CC2 and 'Essential Morphs' Suggestions Please - I want add my own decals. 76% of original size (was 661x19) - Click to enlarge 76% of original size (was 661x19) - Click to enlarge
Visits: 22.1K
It works for me. The input tab is below all the map tabs -- the default on the first decal for jeans is "hole1" but then you can scroll down until you hit "input" at which point the diffuse will show up just fine.
Last Active: 3 days ago
Visits: 62.5K
Try running the "1-Click Verification" in the help menu. It looks like it is not recognizing the "Essential" pack. Do you have the "Essential" morphs available in the Modify panel?
Waterlane Studios
Waterlane Studios
Visits: 309
Thanks for your replies If you see the pictures I've attached you can see I've already selected the 'input' option, but no map-image slots are visible...
I've tried the verification process and it seems fine - and yes, the essential morphs are showing.
I'm adding this to the feedback tracker instead - cheers anyway.
Pete_RL
Pete_RL
Visits: 741
If you only have CC Essentials Morphs & Skins then you will only have Input maps available for the Actor Skin.
If you need access to Input maps for clothing then you also need the CC Essential Clothing & Fabric pack.
Waterlane Studios
Waterlane Studios
Visits: 309
Forum Admin (RL) (5/23/2017) If you only have CC Essentials Morphs & Skins then you will only have Input maps available for the Actor Skin.
Hi - thanks for the answer. you may be right as I don't have that pack installed... How though could I add a decal (eg tattoo) onto a characters skin? I cannot see an "input" option under the body decal. and, for example - If I go to the 'Misc/Body Hair' tab then I can choose 'Input' but the map option still does not show...
Waterlane Studios
Waterlane Studios
Visits: 309
... I cannot see any option to 'use maps' under any body 'input' option - eg Decal on the body or head.???
Pete_RL
Pete_RL
Visits: 741
You should see input map options for decals when you have it selected as shown below. 76% of original size (was 661x19) - Click to enlarge
Waterlane Studios
Waterlane Studios
Visits: 309
Thanks for the screenshot - the input maps are not showing up for me though (here's my screenshot to show you...) 76% of original size (was 661x19) - Click to enlarge
Pete_RL
Pete_RL
Visits: 741
I would advise reinstalling the CC Essentials Morph & Skin pack as clearly something isn't right. Once complete check the log to see if it completed successfully. It might indicate if there has been a problem during install.
