gimmeemythang
gimmeemythang
Visits: 68
Hello! I am new to Iclone7,I am trying to use the time scrubber to trim a clip and cant find the time scrubber,can someone please post a picture or a video of how i can access this correctly.Thank You!
You can also "Delete Frames" in the Timeline Editor. (Of course, that is a permanent removal of frames, but can be very useful when you do a "Save As" to start a new scene that is similar to a previous one, for example.)
If you have any soft cloth physics, long hair, or particle emitters, you will need a second or two of animation before your real action begins to be sure the cloth is settled down, or the emitted particles are visible, etc.
P.S. I will take a moment to once again say "THANK YOU" to REALLUSION for vastly improving the performance in Insert Frames and Delete Frames. It used to that a long, long time in iClone 5, but is extremely fast in iClone 6. I'm not sure if I've done it in iC7 yet. Hmm... I better make sure it still works wonderfully.
Am7add9
Am7add9
Visits: 9.3K
under the preview window is the timescrubber drag the 2 arrows things to where you want your start and end points to be. but you cant trim-comp like AE
Visits: 256
Is it possible to trim the timeline if a scene doesn't start at frame 1? I often find that I start new scenes where old one's end and would like to do something like 'trim comp to work area' in After Effects.
Thanks
