Possible to trim the timeline?
https://forum.reallusion.com/Topic326393.aspx
Print Topic | Close Window
By jmn - 9 Years Ago
Is it possible to trim the timeline if a scene doesn't start at frame 1?  I often find that I start new scenes where old one's end and would like to do something like 'trim comp to work area' in After Effects.
Thanks
By Am7add9 - 9 Years Ago
under the preview window is the timescrubber
drag the 2 arrows things to where you want your start and end points to be.
but you cant trim-comp like AE
By justaviking - 9 Years Ago
You can also "Delete Frames" in the Timeline Editor.
(Of course, that is a permanent removal of frames, but can be very useful when you do a "Save As" to start a new scene that is similar to a previous one, for example.)
If you have any soft cloth physics, long hair, or particle emitters, you will need a second or two of animation before your real action begins to be sure the cloth is settled down, or the emitted particles are visible, etc.
P.S.
I will take a moment to once again say "THANK YOU" to REALLUSION for vastly improving the performance in Insert Frames and Delete Frames.  It used to that a long, long time in iClone 5, but is extremely fast in iClone 6.  I'm not sure if I've done it in iC7 yet.  Hmm... I better make sure it still works wonderfully.
