theorysharp
theorysharp
Last Active: 7 Years Ago
Visits: 115
web3 (2/7/2017) Awesome, thanks I was going to basically model the hair using xgen then convert it so cool. I'm on the right track then ;-)Did xgen work for you and character creator/iclone?
web3
Visits: 133
Posts: 15.8K,
Visits: 31.4K
web3 (2/6/2017) Also has anyone been able to import xgen cards into CC?You wouldn't be able to use those in CC, which is strictly for CC characters. iClone perhaps, via 3DXchange.
web3
Visits: 133
Yes, I've noticed that starting a new scene now seems to be working just fine. Thanks everyone!
web3
Visits: 133
If I remove all of Maya's rigging isn't that going to break the imported FBX?
web3
Visits: 133
Thanks everyone for the replies. I'll give these suggestions a try! I'll report back if still having probs.
vidi
Posts: 10.8K,
Visits: 40.2K
I had the same challenge and all the same Error Messages Until RL gave me the Hint . Open Maya , first Start a new Scene and then import your meshes That seems important Another important step . set in the copy bind weight option Influence accociation to "name" and Export allways with FBX 2012 . Now it works !!! I have now allready create many Cloths and no Problem more.
Visits: 62.6K
It looks like Maya might be adding a new root bone. This is pretty common for a lot of 3D software to do with exports. "CC_Base_Body" should be the root. Maya may very well have stuck in a new root right above that with the name of the file. So check your bone hierarchy.
Posts: 15.8K,
Visits: 31.4K
There are a lot of knowledgeable people on this board as to exporting and importing in connection with CC (not me, I'm afraid), so hopefully they will jump in. Just don't give up yet!
web3
Visits: 133
So i've been able to get a bit further but now I'm getting the following when I try to import from Maya 17:
